FS: 931 Vented Nose Panel
Wax On, Wax Off
drilled off of the 924 Turbo nose, stripped, primed, and painted red. Selling because it wouldn't fit my 924S without taking a grinder to the air vanes under the nose panel... it'd probably fit a later 944 with the nose that's able to fit an intercooler under there, but the 924S, nope. no dice. I'll post pics of it painted...
$100.00 or best offer.
Wax On, Wax Off
Originally Posted by sracer
geoff,
you sell this after I pay money to have my nose panel repainted. ahh well maybe next time
Brandon
Brandon
Ah, I'm sorry.. That brings up an important side note:
WILL NOT FIT TURBO OR S2 PORSCHES...
Also, the paint I did was rattle can... it's kinda gaurd's red...in the right light... so it doesn't match perfectly, and I did a crappy prep job, but it'll be easy to fix my problem..
so you get that far and your not putting it on because you need to bend over two little pieces of metal? wth? Will not fit 944 w/o cutting out or bending the same pieces. I would just cut it and put it on. Its not like you see it if you ever put the original back on.
Wax On, Wax Off
If someone did a search, I have covered this in the past several times, regarding the two small triangles of metal that need to be cut in order to make the vented panel fit a 944. It takes about 5 minutes with a dremel tool and a little touch up paint to cover up the exposed metal from the cut.
Dan, you stole that header panel. Nice job.
