Did anybody say, "Console/Cassette Lid?"
Cleveland Rocks
Some folks have been posting some pretty good write ups recently. Nice to see some good tech stuff come along.
After a recent conversation with MichelleJD and some other fellow Rennlisters, and seeing a few recent references to the console/cassette lid, I decided to dig this one up from the grave.
Console Lid Recovering
Hope this helps. May all your cassette lids be purdy.......
Sweet Do you have a name or part number for that style of vinyl(what was on the bolt?) Here is his write-up.
Well, so was I. Decided one day that I had nothing to lose by trying to recover my own. If I screwed it up, just keep searching, right? I even took some pictures for a write-up just for you guys, so if I did screw up, you could all laugh at my dumb *** (more on that later).
I started out by finding closely matching black vinyl and knowing I would have to work the rounded inside edges, I got the "stretchiest" stuff I could find. Six dollars for one yard, and I already have some trusty Weldwood Gel-type contact cement (I have used it before on the headliner, doesn't soak into fabris readily, doesn't run so it allows you to use more). Stripped old material off, cleaned well, rough cut new stuff, brush on the cement, let it dry......
...and start pulling the sides and corners tight. It helped to have as much glue and fabric contact surface area inside the lid as I could to help hold the fabric. Trim the excess fabric, spot-glue a few areas to help hold for good measure, burnish all the edges down as best I could and voila......
Looked pretty good just laying there, but let's see what the installation looks like.....
Guess it doesn't look too bad, but the laughing part comes in when you start working those round corners and get the cement all over your fingers, and then everything else. Have plenty of mineral spirits and towels on hand (or whatever cuts your adhesive of choice). Hope this might help anyone who may try this.
The Official Jello Sensei
Nerd Herder
Wade. I love you.. If I was a chick..
Is it time for my "Early switch rebuild" to be reposted?
btw- DAMN those seats look good. I have to get up there and recondition the 1993 944fest seat issue.
Call me brother. Sorry about the 68 AMX thing. I thought you might want another one.
Cleveland Rocks
I just tried to give as much info about the type of material used as I could. It wasn't a perfect match, as the pebble grain is more prominent, but I think it looks better than OEM. And because it was "stretchy", it was very easy to work with on those curved edges. I have since used the same material to make a shift boot, replace the aging stuff on the panel that covers the sunroof gears, and soon on my door panels too.
Cleveland Rocks
And I already have the Leatherique for the "03 "Fest Issue" and I have the seat stripped down ready to do. Because of aforementioned "medical issues" I am just now getting around to it.
I used what is called whisper vinyl on my poker table rail and it has a feel of leather, very good stuff. The key to vinyl, is to heat it with a hair dryer and stretch it as you apply it.
I just broke mine off the other day. The cover is in great condition but the plastic that hinges itself to the bottom just split on the edge and now the cover is off. Is there anyway to get that back on?
Cleveland Rocks
I did this to my lid last year, and aside from the joyous fun of wrapping the corners neatly, it was an OK job. The one issue I still have concerns the padding under the vinyl (spongey stuff). There was a section of the padding missing on mine (the vinyl had cracked open and the padding wore away there). I tried putting some new padding in the void but it was too soft and now there is a soft spot on the lid. Anyone know the best type of padding to use / where to get it?
Arash
Arash
Originally Posted by Wade B
Some people have had decent luck buying an inexpensive section of piano hinge from a hardware store to do this. But a few of our site sponsors here have the OEM style plastic hinge for sale, as well as a few other aftermarket places. Prices for the replacement plastic hinge range from around $20-$40 depending on who you get it from.
Arash
Arash
I used bondo, I know, it's a bad word, but I was able to get the vinyl to lay as smooth as OEM.
Got my vinyl from Walmart, near match perfect.
Tip on the corners, use a heat gun or hair dryer.
One last tip, I suggest shelling out the $ for the correct hinge.
My lid was cracked from too much elbow leaning getting in the car. I went to a guy near me that does upholstery work. I asked hime to recover mine but first to put a thin sheet of stainless steel below the foam. He did a great job of recovering it and it looks new and can take the weight of my elbow leaning on it. I have tried to stop that bad habit but when you are getting in the car with something in your hands it is hard not to lean on the lid.
Cya,
Sam
Cleveland Rocks
Originally Posted by SamGrant951
Have you used Leatherique before Wade? I have the whole kit ready to go for the M3 but I just cant actually get myself to head out to the garage and start sanding on leather. I dunno..just a bit timid I guess. The results from other I have seen are amazing. I have cleaned and used the rejuvenator oil (2x)..just need to go start stripping off the old dye and apply a patch/crack filler. eek.
Cya,
Sam
Cya,
Sam
