FR Wilk Chip Review. Finally On Rennlist!
Official Bay Area Patriot
Fuse 24 Assassin
Fuse 24 Assassin
I just finished installing an FR Wilk chip and taking a VERY LONG DRIVE to test it out. Needless to say the flatspots between 2500-3500 RPM are gone. The car is more responsive immediately at 2000 RPM. The car does run rich, but not rich to the point where you can shoot flames out the back of your car.
My exhaust note has changed, the car sounds meaner, throatier, and louder. Many of you know I only have a bullet muffler; well, it's throaty enough to rattle my mom's pots and pans and set my 928's alarm off in the garage
The car is amazing. It feels like a totally different car that will give you a major kick in the **** from 2,000 RPM up to redline! Thank you Mr. Wilk! GOOD JOB WELL DONE! KEEP UP THE GREAT WORK!!!!
Fuse 24 Assassin
Fuse 24 Assassin
jgleano, the FR Wilk chip has 2 programs in it; the factory and Mr. Wilk's setup. To set your car back to factory programming, simply remove the bypass plug he gives you and plug the altitude sensor back in. His program is enabled with the altitude sensor is disabled.
Originally Posted by TheStig
someone else dynoed on Pelican with the chip if I recall and only showed a 3 HP gain.
Did it chage the area under the curve much?
Fuse 24 Assassin
Fuse 24 Assassin
Hey Mac I always run 91 octane in my car (premium for CA). Changing fuel grades is irrelevant for me; but FR Wilk states to run the car on premium, then down grade it to a mid-grade.
