Options for front upper strut bushings....?
... I'm pretty sure this makes sense... The two big bushings/bearings at top of strut towers in engine bay- look like hockey-pucks almost... I understand theseare VERY pricey when new... The rubber is really warped in both of mine- considering their age, it's not too bad, but... I don't want to go spherical bearing, as mine's a street car... any suggestions...? What options do I really have....?
thanks
thanks
A cheap alternative are the strut bearings from KLA. I have them on my car, very well made and worth the price.
http://www.klaindustries.net/strtmnt/strtmnt.htm
How did they affect the ride of the car over rough roads? Did they really harshen up the ride? What about the famous 944 front end shimmy that the rubber mounts were supposed to deal with?
I just purchased a set of camber plates from Dynatech Motorsports for $525 http://www.dynatechmotorsports.net/s...mber_plate.htm. Very high quality piece that replaces the factory bearing. And allows for a wide range of suspension adjustability. If you are looking into upgrading your suspension, camber plates are a key element.
I put in the KLA strut mounts in August. It was not a bad DIY job (I am a novice mechanic at best), and the noise/vibration/harshness is not noticeably worse than the stock bushings. I can't really comment on any performance improvement, as I also put on 4 new tires, new sway bars, and got a much more aggressive alignment at the same time. I give them a 10/10 -- a fantastic product given how ridiculously expensive the OE part is!!
I have the Racer's Edge Camber Plates with spherical bearings and don't mind them at all on the street.
'Course, the rest of the car is much more obnoxious (no rubber bushings anywhere, full cage, track suspension), so I'm not sure I would notice
another vote for the inexpensive KLA units. no problems with rideability.
if you're not tracking it, i wouldn't pay for the more expensive camber plates unless you want bling.
If you want to retain the stock ride but not break the bank on late model replacements, consider backdating to early style for $87/side.
http://www.paragon-products.com/prod...utmountkit.htm
Good Luck!
Good Luck!
UAE Rennlist Ambassador
Skip,
I believe that is what i purchased from you guys when i got the konis, springs and so on......
If i am not mistaken, those earlier types are smoother/better than the newer models?
Yes, the back-dated option was something I had considered- I think I have the later units- they're from a 968 & have a rectangular piece that's about 1" long, 1/2" wide, & 1/2" high- IS THIS what you're talking about, Skip, that's supposed to add the weight to help out w/vibration? Mine, from my Turbo S, did not have this, but, appeared to be otherwise identical...
I'm very leary of camber plates & solid units- I want NO vibration- too much already, actually... mine's a street car- everyday driver, so, that's important to me- plenty of newer cars that handle as well & are more comfortable, but, I chose to buy this car, so, have to work w/what I have... How do i know when the stock units need replacing anyway? Does it have ANYTHING to do w/the shape of the rubber? It looks like mine is slightly warped, but, I can't FEEL any probs... Do I really even need to get new ones? Would I notice a dif if I went w/brand new stock units? I mean, does the rubber have much to do w/it, warped or not...?
WOW! The KLA units LOOK nice- so does the price... I just have to wonder about road noise, harshness, vibration, etc... guess it depends on the rubber question I'm asking.....
thanks a lot everyone...
Well..........mine is smooth, that is untill i hit the crappy roads here
Again, thsi was replaced along with the konis, springs, seals, bushings and so on......i guess adressing the front end just makes teh ride a lot smoother and responsive (duh!)
I'm very leery of camber plates & solid units- I want NO vibration- too much already, actually... mine's a street car- everyday driver, so, that's important to me- plenty of newer cars that handle as well & are more comfortable, but, I chose to buy this car, so, have to work w/what I have... How do i know when the stock units need replacing anyway? Does it have ANYTHING to do w/the shape of the rubber? It looks like mine is slightly warped, but, I can't FEEL any probs... Do I really even need to get new ones? Would I notice a dif if I went w/brand new stock units? I mean, does the rubber have much to do w/it, warped or not...?
The wear is both in the breakdown of the rubber (the warp you can see, and the age/wear-induced tensile weakening) and in the wear of the sealed bearing and sleeve within (non-serviceable). I've got at least a half-dozen sets of used late model units and they are all warped but in otherwise good condition. Tough call on whether you'd feel a discernible difference between new and used.
Good Luck!
Thanks again guys...
Skip- interesting info- how much are the 968 ones new, then? also, do you ever sell used ones? Last, can you give a ballpark on how long they could normally last on street conditions before they might really need replacing? I know there are a ton of variables there, but, in your opinion, based on your experience, etc...???
thanks...
thanks...
