oil temp gauge install.(now with custom gauge holder!)
How about an "instantaneous torque" gauge found on the new Hyundai Tiburon!
http://www.newtiburon.com/forums/sho...&mode=threaded
(its the one on the left above the CD player)
HAHA.
Anways, good idea with that universal DIN gauge mount Ashton. I might have to give that a shot.
EDIT: Nevermind, I'm buying the one Michael posted. Although I need to pick one more gauge to fill it. So far...
Dual A pillar-
WB O2
Boost/Vac
Triple dash cluster-
Oil Temp
EGT
Maybe Oil Press? Or Coolant Temp? Clock?
HAHA.
Dual A pillar-
WB O2
Boost/Vac
Oil Temp
EGT
Campeck Rulez
will the one he posted fit?
i took a risk with this one and ended up having to cut it a little. not so bad since it was soft metal and easily worked with. if that one doesnt fit it looks likw you wouldnt want to cut it up!
anyone have an a pillar gauge thingy to sell?
Campeck Rulez
oil pressure and water temp. junk the EGT.
and get this!!!
http://cgi.ebay.com/ws/eBayISAPI.dll...e=STRK:MEWA:IT
and get this!!!
Thats a cool EGT gauge. I could actually ditch EGT gauging entirely, my engine management can log it, and will probably eventually be able to automatically enrich fuel/retard boost and timing based on it.
Personally i would not get a A/F gauge on the pillar. The ones with the LED's are very annoying at night...my buddy has one on the center console of his Evo8, drives me crazy whenever i am driving it. He has since put electrical tape over it because its so distracting.
A fairly cheap and nice alternative to gauge panels is this one from 968 Engineering, i have one on my car. Very nice looking part and looks stock.
http://www.968engineering.com/gaugepanel.html
Originally Posted by Campeck
the proximity gauges are pretty exspensive. and only measure ditches 5 feet deep.
im thinking more oil pressure ,water temp and then vacuum and A/R in the a pillar.
wuss.
Originally Posted by michaelathome
I spotted these a while back. http://www.42draftdesigns.com/mk4tgp.htm They have quite a few products.
I like this one for $20:
Guages are obviously not included.
Michael
Michael
hi !
do you order it ? does it fix on a 944 ? because it's says tha they fix on a golf and jetta
thanks for the answer
