klr unit
does anyone have a good used klr unit for a 86' 951. i've posted on some other porsche forums so some of you may have heard my sad story, but i managed to short out my cycling valve wires and i suspect the klr unit is damaged. my car cuts out under boost and i've checked everything. last night i discovered i'm not getting a ground signal under boost. i don't need this feature because i'm not running a cycling valve (i have a boost controler) but i think that the klr is dead and not telling the dme what to do and the dme is cutting fuel under boost. any input would be appreciated greatly. thanks.
