Progress?
Originally Posted by aribop
George,
I'm pretty sure I have a spare valve in the garage. I'll look tomorrow when I get home and let you know. It's yours if you want it.
Albert
Albert
Originally Posted by Geo
Lastly, does anybody know what this little vacuum controled valve is, and just as importantly, is it expensive. I broke the hose nipple trying to save an AC line. Probably saved a $5 line while breaking a $100 part.
I removed that entire pipe. I put in a block off plate on that since i don't run my heater lines.
Not sure what that means for SCCA rules, but the car will run fine without it.
I think one vacuume line goes to emissions stuff and the other to the throttle body I capped off.
What that switch does, is creates a connection for vacuum between the 2 nipples on it once the coolant reaches a specific temperature, I believe it's 40*C. If you just ran straight from the TB to the vapor purge valve, you would most likely be fine, since these engines hit 40*C in a jiffy.
That said, I believe you saved a $100 line by sacrificing a $5 part, since you have time on your side, my advice is to get a used one, and keep it out until the very end. The A/C lines are expensive, and it's better to break the valve than damage an A/C line
Joe, I must still run the heater hoses. However, since this is an emissions related part, I can just plug the hole I believe.
