My clutch pedal makes a clicking noise?
It just started doing it today, when you first push it in during the clutch free play, I get a click click click as I push. I crawled in the foot well and pushed it in a few times, listening, and it seems like it is clicking from the lower part of the pedal, and not up inside the dash area, but I could be wrong. It's VERY annoying, and i'm just wondering if I just need to spay WD40 on anything, or if something actually broke.
Thanks as always,
______________
Pat
86 944
95 Audi 90
Thanks as always,
______________
Pat
86 944
95 Audi 90
It's a spring center clutch with only 20k on it, but the clicking is coming from the drivers foot well pedal assembly someplace, I think I can even feel it on my foot.
____
Pat
86 944
95 Audi 90 CS
____
Pat
86 944
95 Audi 90 CS
Anyway did u fix it or sell it?
I have an annoying noise coming from my brake pedal. I think the problem is the brake switch need lube or replacement.
The clutch pedal doesn't have a switch (unless perhaps cruise control uses one to stop cruise). The sound you are describing makes me think bushing or spring (pedals have return spring).
What I'd do:
REMOVE SEAT. Sorry but it's gotta be done.
Lay under and watch the pedal components to determine the source.
Lube or fix or replace the source of noise.
What I'd do:
Don't use WD40. Use a can of lithium spray lube. The kind that sprays out liquid, but solidifies into grease. They will get into the bushings and linkages when it need lubrication. Just be careful the grease doesn't get onto the switch that controls the engine starter.
For the record: I adjusted my clutch pedal and was able to reach in and around with the seat installed. I'm 6'2". The hard part isn't getting under; it's actually getting back OUT. That was a funny scene!
So more of an earnt earnt click and earnt earnt click with each gear shift as clutch goes to floor and back up to top.
Nothing loose in there and spring is new blue With plastic bushings and all ok. in fact all looks brand new up there wires and alll metal for a car with 130k on it
as I shift with my hand I hear a clink clink under the car very very faintly. Maybe thats normal too? Clutch is nearly new according to measurements from that hole you can look into from below, so previous owner must have changed that rubber thing out at say 100k. Shifts real nice except for that damn downshift shudder thing to 2nd which I just never ever do after trying it once. Some freak thing on 944 S2s I guess. I thought the gearbox was gonna drop on the ground. That was five years ago and 30k ago now.
this click seems somewhat benign to me. Maybe I will just drive it and enjoy. Til some washer or bolt falls onto my feet?
If you are just sitting idle in a garage & listen too closely, you'll usually hear some sort of noise; there's a lot of action made with that pedal. But, if you're outside driving at speed and still hear noises on top of the motor & exhaust, I'd say something ain't right.
This shudder you speak of: if, before your downshift, you cruised a little off-throttle, the engine may have cut fuel and re-applied when you completed your downshift (it cuts fuel by design off-throttle). This can result in a very harsh re-engagement, shuddering the whole driveline. Ugly but normal
This shidder thing you speak of before your downshift, you cruised a little off-throttle, the engine may have cut fuel and re-applied when you completed your downshift (it cuts fuel by design off-throttle). This can result in a very harsh re-engagement, shuddering the whole driveline. Ugly but normal
I am convinced that none of these cars had any sorts of odd issues when new; they would have failed test drives!
I'd be curious if newsgroup posts from the 90s complained of this.
I would guess what we're seeing is common failure patterns due to age. AFMs are going, resulting in whack A/F ratios; clutch parts old; rubber bushings are brittle; bearings have play; etc etc.
In 1990, not one 944 derivative "pulled left on the highway" or "shuddered when downshifting in 2nd" or "hesitated first few km after cold start" and so on.
I don't buy it! Maybe all S2s exhibit similar aging or wear symptoms. I'd bet with a rebuilt engine, new AFM, new DME, new clutch, new trans, new TT, your problem would disappear![Big Grin](https://rennlist.com/forums/images/smilies/biggrin.gif)
:thumbupI would tend to agree when new they never did this. Thats why some think it is a form of one of the aftermarket clutch disks post rubber disk upgrade. If only we didnt have to send our kids to college. ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
Meanwhile this darn clutch click thing persists. I suppose it will be years before I figure this one out
Now that I reflect on this post compared to my brand new jeep that has its own creaks and rattles it sounds kinda funny. “My 30 year old car makes a little squeak noise now, Why does it do that?” LOL I do love these cars!
For all the aging issues, these cars are relatively well made and quality. For sure! I am reminded of this every time a colleague complains of a suspension or exhaust issue on their 201* whatever car
