HUGE cooling problem
Well now that I've refilled my cooling system there seems to be a substantial leak. After the car has run for about 15 seconds it starts smoking A LOT from the exhaust manifold. From the 3rd cylinder pipe to be exact. It's white smoke and does not increase in volume when I give it gas so it is not a crack in the pipe. And the temp needle climbs steadily into the red. I got a pressure tester and pumped up to 14 psi. After a few min. I noticed a line of coolant on the underside of the exhaust manifold from the 3rd cylinder, but I can not see where it is leaking from. The two heater hoses seem to be fine at the connection to the heater core. I orginally thought it was my waterpump that was failing, but now I am begining to fear I have a crack in the block. Any thoughts?
Originally Posted by jonnybgood
Pulling the spark plugs may give you a good idea if it is a leak in your head gasket. #3 plug would be very wet.
Originally Posted by CCCP
if it did get into the chamber, wouldn't it just burn off?
edit: re read your post. you should look for a leak around the gasket area where the head meets the block. If it is not around the gasket area then perhaps you have a crack in the head somewhere. Perhaps removing the exhaust header would reveal the source of the leak.
Yea tomorow I will pull the head and examine it and the block. Now I am hoping it is the head gasket that's blown. Is it even possible for the block to crack enough to have a sizable amount of coolant leak out? And any tips for tomorows head removal?
Resistance is Futile
Check the underside of the heater tube to see if it's got a hole in it... once the fluid pressure builds up it may be hitting the manifold over the exhaust manifold and steaming off of there...
Any report on where the leak is?
I think I have the same problem. I'm afraid it might be the head gasket but I'm hoping its the heater tube. Have they (the heater tube) been known to fail?
My guess would be to take a good look at the waterpipe that goes from firewall (heaterhose) to the waterpump. I may have a fracture in it, thus spilling coolant on the manifold?
Its that, or the headgasket. Think positive!
