924S3 Update
#91
Originally Posted by RedlineMan
Oh Hell... could be lots of things. Reference sensors too. No signal means no sparky. Maybe I'll check the FSM for you?
I pulled up the DME testing in my manual and will work on that tomorrow after work.
I'm also worried about the alarm system. I used the bypass from Clark website, but still no spark.
#92
Originally Posted by Lemming
Thanks Tifo, my yahoo (XXX.XXX) has most of 1 gig left, that will work.
We have the fuel pump running and power to the injectors and coil but we cannot get a spark.
Jeremy
#93
Originally Posted by tifosiman
Email just went out to you with the scans. Let me know if you have any questions.
Jeremy
Jeremy
![crying](https://rennlist.com/forums/graemlins/bigcry.gif)
#94
No problem! Well, I can send you a couple of my homebrews if ya would like!
Man, what kinda woman takes a man's collection of homebrewing equipment? That's just wrong. That reminds me of that quote from Tom Arnold in True Lies about his ex:
"She even took the ice cube trays out of the freezer. What kind of sick b@tch takes the ice cube trays out of the freezer?!?!"
#95
Here are the wiring changes, for the most part. There is one difference I will have to check out... one of the terms HAS to be grounded out, or else the fuel pump wont run. Gimmie a little bit, and Ill figure it out.
#97
#100
Congrats
It took me quite a while to get my car started after my swap. I had multiple problems to contend with - my fuel pump decided to stop working, the ref sensor, and grounding out one of the term's...
Have fun!!!
Have fun!!!
#103
Sorry to dissapoint everyone, but she's not in driving shape as of yet. She is running but I still have more to do. Right now she only has exhaust headers, no exhaust. Early next week she goes to the shop to have a 2.5" exhaust installed.
What did get done today. Well, I got the DME talking with the car; having the "real" 924S wiring diagrams was essential (thanks Tifo). After the mess on Sunday trying to use the Haynes manual, I was sure that we fried the DME. The first thing I did was to pull it and put it in the 968 coupe, which started right up, thus, the DME was ok. I then began with the wiring, but still no go. I finally got smart and pulled the workshop manual and began the DME diagnostics. Low and behold, the second test told the story, no power going out of the DME. I attached a switched 12V source and the car fired. Needless to say, I was smiling.
A good friend then showed up and we proceded to get the gauges going. So far, everything is working except the tach. Not sure way, still need to work on that. I've decided to wire the radiator fans to two toggles on the dash so that I can run one or both as needed. The dash needs to go back in, but I want everything wired up first. I have two water hoses that I blocked off that are leaking so I need to get to those as well. We removed the headlights, and all associated hardware, so we began fabricating brackets to hold the headlight covers in place. I also ran some piping into the left headlight to house the KN filter. I pulled the front drivers side marker and plan to make a scoop to bring in fresh air; hope it doesn't turn out ricey
. When I get time, I'll isolate the filter from the engine as well. Lots of other little things on my list to "finish", but I'm seeing the light at the end of the tunnel
![ducking](https://rennlist.com/forums/graemlins/icon107.gif)
![cherrsagai](https://rennlist.com/forums/graemlins/drink.gif)
#104
Work has kept me from the garage for the last week, finally managed to get time today to work on the 924S3. I got all the water leaks fixed properly and mocked up the air intake system (still waiting on the K&N to arrive; see photo below). All the wiring is pretty much done and the dash went back in (see below), at this point I just have to make the plates that will hold the toggles in the dash.
Issues. During the initial wiring, I hooked the DME 12v power directly to the battery and all was fine. Because the connection calls for a switched connection, I spent quite a bit of time this morning trying to set this up. No matter what switched circuit I attached to I did not get spark but direct wiring always worked. In the end I decided to wire the DME to the back side of an unused fuse and put a toggle on it. The toggle will be placed next to the Key and I'll just flip it on prior to starting and off when I'm done.
I wired up both radiator fans to toggles so that I can control them directly, and did the same thing with the wipers (no park feature, oh well).
I had to order a throttle cable, which they have to get from Germany. Luckily I got one off ebay tonight
so I'll cancel my order. I've not quite made the 9/15 build date, but I'm really close.
