924S3 Update
#31
It is my understanding that you need to use the S2 flywheel. I haven't done this and I only know this from memory of reading other threads about the 968 swap.
do a search on engine swap.
#32
Yea, that's what Matt says as well. Anyone know the part numbers on the speed and reference sensors for the 924S and the 968?
More progress made tonight, I pulled the dash and took out all the blowers and such.
#33
Strangely enough I was wondering what my car would look like without the dash when I was fixing the odometer earlier this evening. I really like the lift, by the way! What is the interior going to look like when you're done?
#34
The dash is going back in, I just wanted to get rid of the weight hiding under it. I still need to clean it up a bit, remove some of the glue and such. Once that is done, and the 968 engine and 951 tranny are in the remainder of the cage will be built.
#35
Between travel and being without power for most of a week, I've finally gotten back to the project. All belts, rollers, and most gaskets have been replaced on the engine. The engine has been put back into the car but there is one problem that I've found, the engine hits the brake master cyclinder. I removed it and was able to bolt the engine up, but cannot if it is attached. Suggestions are welcome at this point.
#36
A couple of thoughts. Have you looked at how the servo/master cylinder on a 968 is located? Would a 944 S2 Manifold work in place of he 968 unit?
Another option maybe to replace the unit completely by using a custom pedal/master cylinder setup (ie the sort of thing used in kit cars and single seaters) and a remote servo.
#38
It looks like the 968 mounting plate is shallower and pointed up more.
Failing this, has anyone run the master without the brake booster?
#39
#40
no suggestions on how to fit that master cylinder, maybe have a new tank for it? But i just wanted to say sweet project and good luck that car is going to be extreamely fast when ur done.
#43
#44
awesome project, should be fast as hell and handle like nobody's business. are you preparing for a specific PCA class and what all is allowed?
#45
Nerd Herder
Good god Tim. That is going to be AMAZING!> I drove Marty's 968 transplant in his 87 944S and is was lethal.
Youre gonna kick some butt on the track. DONT go widebody, then it'll look lkie every other 944 out there..
j/k.
j/k.
