HELP! Serious Vibrations
Just picked up the '87 105K Miles. Drove from DC to Virginia Beach over the weekend and drove her on Monday with no problems at all. This AM pulled out of the driveway, hit the road and serious vibrations appear when running over 30mph. No vibrations at idle so I don't think its an engine mount issue. Shifting just fine, seems just with speed the vibrations appear. Where should I start?
perhaps check balance belt? although I THINK balance belt problems would smooth out at higher RPM?
Did you hit any big pot holes lately? maybe take the car in for a balance/alignment.
Official Bay Area Patriot
Fuse 24 Assassin
Fuse 24 Assassin
only thing I can think of if everything checks out with the balance shafts would be severely worn tie rod ends, bent tie rod or ball joints.
The balance shafts really only come into play at lower RPMS, like idle. If your motor isn't shaking apart at low RPM's, but is vibrating a lot at higher RPM's, it wouldn't be the balance shaft belts.
First, check tire pressures. If you have even 5 psi difference from one side of the car to the other (left to right, not front to back), it can result in shimy and vibrations. Also check for flat spots on the tire, and something your tire may have picked up on the road.
Next step: Perhaps the tires are out of balance. Check to see if the wheel weights haven't fallen off one or more of the wheels.
Next, as Stig suggests, look over the suspension. A-arms, ball-joints...etc. Look for anything that has a shiny or 'just cleaned' look vs. the rest of the components -- they typically means something has been rubbing against the area and may have now broken. Check the bushings in the suspension, sway bars..etc. If you are getting a knocking sound from the front of the car during hard cornering, it could be a caster block bushing that is shot. But a bad caster block won't cause vibrations. Check the rear CV joints - make sure they are not missing any screws. Also check the front wheel bearings -- if they are shot, it's usually a higher- frequency vibration that is felt through the steering wheel. (To test the front wheel bearings, lift the front tire off the ground, put your finger on the spring, and spin the tire -- you should feel no vibration if the wheel bearings are ok. Repeat on other side)
If your wheels/tires and suspension are fine, verify that your motor mounts are solid, and not too worn. This tends to cause harsh vibrations in the motor, but again, this would manifest itself at lower speeds/RPM's too.
Hope this helps,
-Z.
Hope this helps,
-Z.
If the vibration is bad enough at 30 to feel it will not be wheel weights. I would check the tires for damage, particularly for sidewall bubbles.
Best Car Insurance | Auto Protection Today | FREE Trade-In Quote
As always lots of ideas to check on, thanks for all your input. I have a feeling its tire related so I'll start there based on your recommendations. Any other recommendations still welcomed. Thanks
I thought of the CV joints but I hear no major clicking thats usually comes with the bad CVJ's. The vibrations I get are more of a low freq growl than clicking or high speed vibrations. How big and expensive of a job are the wheel bearings?
Check your lugnuts to ensure someone didn't try to aquire your wheels, or that they weren't left sorta loose and somehow worked their way outward.
Is it from the front or the rear? Feel it in the steering wheel?
Updated Info: Still Need Help
Ok, idle is no issue only when driving is the problem. Took a short drive around the neighborhood this evening (20mph or less) and when "coasting" back into the driveway (In neutral) the car would buck slightly as if someone was pulling on it then letting go. Short bursts of drag. When stopped in driveway which has a slight incline the car would almost not roll back while in netural. Its like it sticky, whats going on. Help???
PS I checked the axles and no bolts are missing. There are not shiny parts showing and nothing looks out of place. Nothing hanging etc. Also pulling out of driveway I heard a single click but wheels were straight.
While you are checking things, removed the rear wheels and check the brakes. However, it sounds like you have an axle that is failing.
