Early car gauge swap?
Hey,
I remember reading on the boards recently about swapping the postion of the speedo. and the tach. I tried searching but I couldn't find anything. Does anyone know how to do it?
Thanks!
Mike
Thanks!
Mike
Pretty straight forward. You must remove the gauge cluster (which requires disconnecting the speedo cable). The gauges simply push out from the cluster. Then swap them. My understanding is there are slight issues with the length of the speedo cable and the wiring harness. Do a search and you can find more info.
I'm actually surprised that the tach wasn't set in the middle in the first place. I read somewhere that Doc Porsche felt the tach was the most important gauge and as such should be in the the middle of the cluster, ala the 911.
Nerd Herder
Geo is correct- I'm also surprised. I drive by tach.
the speedo cable seems just a tad short if you plan on moving the Tach to the center and the speedo to the right of the early dash/ it can be done with some planning so as not to kink the speedo cable.
Late dash? I would think it's just the guage swap, no spedo cable to worry about reach- but I'm not nearly as familiar with the late dash
I did it a while ago and then switch it back about a year later (early dash). IIRC, I had to push the speedo cable back a bit and reposition how it passes over the steering shaft. Also, regarding the wiring issue, I seem to recall it could be worked around by changing the lamp holders around, which created enough slack to swap gauge positions.
One other issue I encountered is that there is a big nubbin protruding down from the underside of the dash that seemed to kind of hit the top of the tacho when it is in the center position. The tach body is a bit deeper than the speedo body. I think the nubbin must be a stop or something to help keep the cluster in position. In any case, it kind of pressed on the tach and made the dash push up the tiniest little bit, which made the dash crack that was already right above it look worse.
In addition to swapping positions of the guages, are there replacement guages that put the needle sweep on the top rather than the bottom? I mean, I prefer having the tach needle at 12:00 for near redline. IRRC, the tach needle on mine sweeps along the bottom, which seems counter-intuitive when getting out of a 911.
This was pretty much a DIY where I replaced the cone shaped "glass" (plastic) with flat and had a sticker made to cover the factory markings.
Originally Posted by ZV
You can spin the guage to any orientation. It just friction-fits into the dash on the early cars.
Here is the link, with photos on the install >>
https://rennlist.com/forums/944-and-944s-forum/142026-swap-tach-to-center-position-on-early-dash.html
I did this last year. Best mod I've done to date. My odometer just stopped working too last week. I'll fix it and then take the tach face out, scan it and turn all typography 180 deg in photoshop and print out a new one so it won't look like my 2.5ltr revs to 9,000 rpms anymore.
Nerd Herder
Originally Posted by pearldrum944
um...was title of this post really "early car gauge swap"? Wow....
