What can cause a power steering groan?
Wax On, Wax Off
My buddy's 944 apparently "groans like a glacier" when he turns the wheel... He was low in the resevoir on power steering fluid, and it was dirty as hell, but when I've been low in the 924S, it's never groans...
FYI, the car is basically missing 1 power steering rack boot, it's there, just shredded...damn PO...
Also, this happened AFTER we removed the power steering pump to gain access to the oil cooler... I dunno what the train of thought was, but the power steering pump was hit with a hammer in the process of removal...I'm geussing it was a bad idea...
Old age...budum dumb
I have had this happen on occassion on an na.
It generally occured at the end of the travel.
Low on power steering fluid was my real problem. It was blowing past the end seal into the boot.
low fluid, bubbles in system...caused by a leak!
- Julie
- Julie
My car also had the old-man groans until i opened up the reservoir and found it needed some more fluid due to a clamp on the return line being loose. BTW a good way to change the fluid is with a large syringe, empty out the reservoir and refill, drive it for a while and do it again until the fluid is clean. I am pretty sure this idea came from someone on here, sorry i forgot who it was...but thanks worked for me
Good Luck!
Erich
Good Luck!
Erich
You recently removed the pump, and the fluid is dirty (probably brownish in color?). Your opening post should have all of the clues you need to remedy the problem....................
There is air in the system due to the recent removal of the pump, and the fluid is dirty. Either one of those problems will cause a groaning noise.
Flush out the old brown gunk, refill with new, and bleed/burp the system by turning the steering wheel back and forth to full lock a few times.
Wax On, Wax Off
ah, I suppose I didn't specify... when we removed the pump, we pulled it off the bracket, but did not remove any of the hoses... the system remained closed. I'll advise that the system needs a bleed/refill.
Thanks for the help guys!
Ive posted this here a ZILLION times use (SEARCH)
oh.... ok, mate seeing as its you
CHANGE Da Oil
completely drain and refill,
but seriously if you do a search I've said why it does this at length and also the best way to change and bleed the system.
if you cant find it HOLLa and I'll re-post it
BUT change the oil
laters homie
Ade
HTH
ooops then I read the question.
make sure the oil level is correct (using the dipstick)
if its low, your loosing, you should NEVER loose oil, get it over some paper and check, replace the boot, you will get a knackered PS rack, but anyway
same reply afterwards, change OIL
a related question......what if the rack makes a "bong" or "bing" sound when you turn the wheel? mine has been leaking fluid for a while (everything i try to fix doesn't help) and i finally gave up. now it's starting to make a weird "bong" sound and i think it means it's going bad.
if i bought a power rack from a car 85.5 or later, could i swap tie rods and still use it?
