Question of worth
I have an '83 NA motor that I bought a while back and have been overhauling for my car. Rrecently a friend expressed interest in buying it so I'm trying to figure out what it's worth.
Spec's
-'83NA long block 130K miles
-Factory cross drilled crank
-New rod bearings
-Late oil pan and baffling
-Balance shafts resealed
-Rebuilt water pump
-New timing belt
-New balance shaft belt
-All new rollers
-Front end resealed (Crank, Cam, Balance shafts)
-New Sachs clutch set
-New head gasket
-New cam tower gasket
-New intake and exhaust manifold gaskets
-New exhaust manifold studs and nuts
-New vaccum lines
-Resealed oil cooler
-New oil pump drive sleeve
-New thermo valve
-Reseated the valves
-New valve stem seals
-Lightened stock flywheel ~12lbs
On the inside the cylinder walls are flawless, and the motor ran 175-180PSI compression numbers when warm before it was pulled. Motor came out of an automatic car and judging by the condition of the bearings it wasn't ragged on much if at all. Basically this motor was completely rebuilt short of the mains and the rings. Please let me know your honest opinions as to what this motor is worth if I were to sell it. TIA
Spec's
-New rod bearings
-Rebuilt water pump
-New timing belt
-All new rollers
-New head gasket
-New vaccum lines
-New thermo valve
Sad I know.
I too would have hoped you could get that...but the sad fact is a good dvd combo or a PS2 is worth more...sad commentary...but let's not even get into the 928
I concur with Serge, the documentation is the ONLY thing that would raise the price.
Sorry, these cars aren't worth ****, too many made. when it comes to parts.
- Julie
- Julie
You would be able to get a little more if you had done the mains and rings. Then it would be a full rebuild.
If you want to sell it and make anything ebay is your best bet. You may want to shop around for your next rebuild kit. I payed $1100 For everything top to bottom including new rings to rebuild mine.
Originally Posted by Chris_924s
I think 1100 for a full rebuilt engine is fair.. I agree with Wolfe- time to buy a running spare "just in case"..
I was told I'd have to buy a whole new head to get one. $1500.
At prices like that, if certain parts only come with an entire head, it'd be a wise decision to buy a running spare. Thus, as soon as I get the car paid off, I'll be looking for a fresh engine to pack away for a rainy day. Just in case.
These days, I still have a head problem. But it doesn't have anything to do with cars
![grr](https://rennlist.com/forums/graemlins/cussing.gif)
The funny thing is that the parts, Gaskets seals, Rings, bearings, waterpump belts rollers. ect come to $1100 So how is $1100 a fair price? Not saying that it would sell for more but If it is $1100 in parts. + block, pistons, head ect and labor is all free? If you want to sell the engine throw it on ebay. Someone out there will need to replace a blown or knocking engine and once they price out parts they will bid.
I was offered $1800 for my fresh rebuild from an ebayer. Problem is that you can pickup used engines for these dirt cheap. Of course then you are in for another rebuild but that is another story.
As far as proof goes I can prove pretty much everything since I did it and I have receipts for it. The only thing I can't prove 100% is the accuracy of the compression guage, I have a video clip of the compression test being performed.
