Replacing Hood Struts
job should take about 10 minutes.
have a friend watch the hood so it doesnt press against the window.
dont raise the hood - keep it about 3/4 of the way up.
connect the shock at the fender and use your body weight to compress the shock and hold it at the hood and slip the pin in.
There a little hard to compress and hold, but easily done. Get a buddy, and the two of you can press down.
Dont be "girlie-men".
![hiha](https://rennlist.com/forums/graemlins/roflmao.gif)
i use my cheater pipe to prop the hood up and have rags behind the hood, and press on the strut myself. the hood isnt up all the way, just like what was said earlier. ive only worked with help maybe 4 times on any of my cars.....im a very lonely person.
Originally Posted by 89AZ944
Having tried to do this by myself (and failed), this IS a 2 man job!!!!
I did it myself in about 5 minutes. You don't need to compress the shocks! Just get a pair of vice grips and lock the other side fully up then you have the freedom to simply slap the other shock in fully extended. Repeat for other side.
You do need to compress the shocks slightly to install. Just put them in the freezer for a little while (hour or so) prior to installing so that they are "sluggish" and don't return to extended position too fast, then compress to the proper length and act quickly while installing. It should easily be a one man/woman job. If you have the mechanical ability to install your new group-buy valve stem covers, sheepskin seat covers, or aluminum sun-visor clips, you can do this.
Two people realy helps.
One to compress the other to guide and insert the pin.
I don't know how you could do it by yourself.
Although I could just be a puss.
