Momo Shift knobs
Old May 27, 2005 | 11:33 AM
Mike C.'s Avatar
Mike C.
Default Momo Shift *****
I'm looking at some of the Momo shift ***** that Vertex sells. They indicate that these will fit a 944 (in addition to anything else from a 356 to a 930) but there is no information regarding how it would be adapted tot he rectangular shift shaft. Has anyone used on of these? They show a shift boot-**** adapter but nothing that seems to address the differences between round and rectangular shaft mount. I haven't had any luck in raising anyone in thier tech support either....
Old May 27, 2005 | 12:03 PM
Carl Nall's Avatar
Carl Nall
BTDT... The adapters are available from Performance Products, et al, BUT, IMO, you should stay with the OEM shifter. As in many such "upgrades" the original parts are far superior. Aftermarket ***** are noisy, buzzy, rattly, and did I mention, unbearably noisy? If you want to functionally improve your shifter, retain the OE shifter and get a short shift kit.
Old May 27, 2005 | 12:30 PM
streckfu's's Avatar
streckfu's
I have the Momo Combat on the SFR short throw lever and haven't had any problems. It's been on the car for a two years and I can't say that the noise level or buzziness is any different. It has worked loose a couple of times but was fixed easily by tightening it again (it never came off while driving!).
I don't know how vertex adapts for the round Momo **** but the shift ***** themselves are fine. It's a preference issue that you won't be able to answer until you drive with it. Some people like that Momo while others won't use anything but stock.
Old May 27, 2005 | 12:31 PM
Mike C.'s Avatar
Mike C.
Hi Carl, I already have an Autothority short shift kit in there and have shortened the stock **** about 1 inch. It works fine but I was replacing the boot, messed up the plastic **** insert and for a little more than the cost of a new stainless insert I can get a decent looking Momo leather ****. The installation instructions I've seen for these show a rubber bushing being used. Did your installation use this? I'm not really worried about a little extra noise - I guess I'm a little bored with the stock look....
Old May 27, 2005 | 12:34 PM
Mike C.'s Avatar
Mike C.
Hi Daniel, did you use the rectngular to round adapter on the shaft? If so, what does the adapter look like?
Old May 27, 2005 | 02:49 PM
Carl Nall's Avatar
Carl Nall
In my experience, the adapter did not allow use of the rubber bushing, the fit was too tight. I suppose you could reduce the size of the adapter or bore out the MOMO **** to allow fitting a bushing. Presumably, that could help with the noise, vibration and harshness issue.
Look at this old thread: https://rennlist.com/forums/showthre...t+****+adapter
Old May 27, 2005 | 03:01 PM
streckfu's's Avatar
streckfu's
The SFR lever I have has the square upper removed and a round piece welded in it's place.
Old May 27, 2005 | 03:02 PM
Mike C.'s Avatar
Mike C.
Thanks guys. I somehow missed that link during my search. That was what I was looking for.
Old May 27, 2005 | 03:04 PM
streckfu's's Avatar
streckfu's
Here's my old thread showing the lever install. You can see what it looks like here
