stripped seat bolts
1 Post
stripped seat bolts
Well i planned on taking out my seats today to give it a through clean up.
Went over to the pass. side seat to take out, took one bolt out via a 6 mm allen wrench. i went over to the second and found out the head was very worn out. My allen wont fit in there and if it would there is nothing to grab onto. What is the best way for me to remove these bolts? Given where the bolt is, its very hard to get too many tools in there, im having enough trouble with the allen.
and once i do get it out, would i be able to find bolts like these at a hardware store? if not, where?
Thinking outside da' bun...
You have just entered into one of the absolute worst abysses of the Porsche ownership experience. Stripped seat bolts that wont come out.
I insulted and damned just about every living creature and ethnic group trying to get mine out. First of all the design is absolute horsesheite given that the bolts are contained on three sides if I remember.
The only way I found to remedy the situation was to get a big drill and drill those mother ruckers out until they just break apart into pieces and you can pull the pieces out.
If my seat bolts ever get stripped again you will see me on the nighty news.
A good caring rennlister spared a set of replacement bolts for me. I think you can find them at Tweeks etc but Im told any bolt with the right size and length will work. No, I dont know what that is.
UDPride is not kidding. The PO stripped the bolts on BOTH of my cars. On one I was able to hammer in a bigger size allen, and on the other one I had to bust the seat rail and replace it with one from a ripped seat. I hate those things..
1 Post
well i got the stripped bolt out... i jus stuck a bigger allen in there and managed to get it out..
i have one more bolt that doesnt want to get out!! The allen fits in there fine and it isnt a matter of a stripped bolt; well not unless im stripping it trying to get it out. It wont budge! i sprayed it down with wd 40 and still nothing. I think im gonna take a hammer to it, or maybe drill it out if i cant get it out.. Sunlight is going away, and i havnt even removed one seat yet...
whats the stuff i read so much about, PBblaster? is it any better than wd 40? same?
When your able to replace the hardware, i recommend also buying the allen key socket. Its SO much faster with the socket. I took both seats out maybe 3 times before i finally bought the socket and was amazed how much time i saved without having to use the stupid allen key. If i was crazy, id just take the seats out for the hell of it because its so much easier!
1 Post
So after a day of trying, i got the seat out!!! THe last bolt required some.. uuh... tuff love but it came out.. stupid bolt..
well, after thinking that im going to be finding millions of dollars stashed under the carpet, i end up with 27 cents. not to mention new bolts i need to buy. Found one very tiny lil screw i have no idea where it goes, a long screw with a bigass washer that i tihnk goes somewhere near the DME..
i found 2 of the washers that should have been under the bolts that werent.
now for the what i needs.
the bolts ill be able to get at a hardware store.. but i need the brackets or braces that go under the rails, for some reason mine dont have any. I can see the stained place where the brackets belong. any idea where i can get some?
thanx for the input and following my struggle today. 5 hours and one seat out...sounds like a productive day
A trick I used to remove a stubborn and stripped seat bolt was to use a 'star' or 6 pointed torx type thingy - a T-20 or T-30.
Sorry for the cryptic response. If you need, I can dig around my tool box and find the exact name of the tool I'm trying to describe!
-Z-man.
-Z-man.
Location: Albany, CA: celebrating 100 years of independence from Berkeley, CA
1 Post
Thanx Joe... a whole day for one bolt i tell ya.. nonsense!
tomorrow ill be cleaning everything and poutting the seat back asap.. ill post a pic of the dreaded bolt later.. i ripped him a new one..
One more thing to remember when you go searching for bolts (which I thiink should be available at a good hardware store) is to get the right grade bolt as your seat belt is attached to the seat. That's also why there are 6 of them, earlier cars only had 4 but the seat belt attached to the transmission tunnel.
If you are talking about those L shaped brackets under the seat rail the bolts screw into, they look pretty common in size. If someone here has the dimensions Im sure any hardware store will have them.
Id rather give birth through my rectum than mess with stripped seat bolts again.
Geaux Tigers!
-Z-man.
-Z-man.
