To part out or not part out....
Okay guys and gals....a little thinking out loud. You know the story....guy buys a 944 as a parts car, begins to see potential, doesn't want to part it out...wonders if it will be "worth it"
The good:
very decent exterior, nice 15 x 7 Fuchs
Engine
The bad:
Car was parked about 2 years ago due to clutch slipping. No brake/clutch fluid in the vehicle at all
The interior has had it musty, moldy, bugs etc
Lots of loose wires from the former stereo
Not necessarily looking for anyone to make a decision for me, just want some insight or experience others may have had. Part of me wants to give it a try (get it back running) but do realize if start throwing too much $ into it, I'd have been better of buying another running car.
This is a black 1983 NA.
The good:
Engine
The bad:
I'm going to change the timing belt before I try and fire her up. My other question to those that have done it, what else did you do before you tried to start it? It has been sitting about 2 years.
What I would do with a car I wasn't familiar with the history of:
Turn the engine over by hand some before running the starter after you do the timing belt, but that's a good idea for timing belt work anyway. You'll need a new battery, of course. It's not a bad idea to turn the key to 'on' and give it a minute to sit there before cranking (just in case the smoke decides to come out of a few wires). Keep a fire extinguisher nearby and the hood open, just in case.
The one major problem the '83 car had was, as the PO put it, 'it had no oil pressure...then I drove it home and found the cluch leaking' After the car sat for so long there were many issues with it from the interior smelling of cat pee to the exterior needing a paint job. As well as the unknown motor problem, that turned out to be a blown gasket. The clutch leak was due to the slave being blown.
