Odometer, speedometer questions...HELP
my speedo and odometer will work erratically, and sometimes will not work at all. Is this due to a lose connection, or what? Can anyone helpo me with this or tell me how much it will cost to get fixed? any help would be greatly appreciated
You may want to check the connections on the back of your dash. Or check to see that the gauge is seated on the 4 pins correctly.
http://www.rennbay.com/odotutorial.html
Check this out:
Check this out:
Where in NH are you? I may be able to take a look, if you can bring it by?
John D.
(BTW: I deleted your FS post.. If you want to know why - go here:
https://rennlist.com/forums/924-931-944-951-968-forum/195207-the-thread-from-hell-was-fs-unique-85-5-944-a.html
John D.
![EEK!](https://rennlist.com/forums/images/smilies/eek.gif)
yeah man put what car/year etc you have in your sig....go to your control panel and fill it in. its hard to diagnose a problem when you dont know what your working with.
that is electronic driven from trans...i would check for loose connections front and rear.
That is just a loose connection at the back of the pod. Pull the pod and unplug / plug the connectors in the back. You pull the pod by taking out the screws in the bezil above the steering wheel, and the ones in the vents. Remove the bezil then take out the 4 screws holding in the pod. Reach behind the pod and remove the connectors. They have little arms on them with swing out to release. Plug them back in and test. You should be good to go.
Nerd Herder
John D.
https://rennlist.com/forums/showthread.php?t=195207
John D.
Offer Stands- Make your way to Cincy and I'll teach you how to fix it.
Originally Posted by Chris_924s
...Offer Stands- Make your way to Cincy and I'll teach you how to fix it.
But - are you offering beer - I could make it to Cincy for that????????????
JD
(Ummm - a 944 has the engine in the front - right???
Nerd Herder
John- you KNOW you are always welcome in my crib, and always a beer.
John- if you get another 944- I'll do your wiring.![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
BTW- I'm moving to central Cali. You have a quick trip and a sleepover from Big Sur coming sweetheart.
I live in manchester new hampshire. I have yet to attempt anything with y odometer because of some domestic battery theft.... but once i reclaim my battery I will have to let you guys know if i fix it or not.
