Fuel lines what's the trick?
OK so I go to put on the SS fuel lines and I can't get the compression fitting to seat right. There isn't much room to work near the fender and I just need to get it to go about a 1/16in more. it seems like the line is out of round right before the bend. I even tried putting the fitting on all together and pressing it on but no luck.
Are you fitting them inside the engine bay or in the wheel arch? I found that a mini pipe cutter got the end nice and square, and then had to just clean the paint/coating with some fine wet&dry to get the 10mm compression on. The 8mm fitted just fine.
Well I had to go trough the wheel well because I couldn't get a clean cut through the engine compartment. Now I have the space but I already compressed the fitting so I have to wait for a new one. I tried all of the local shops and no one had anything even close to 10mm.
And before anyone else makes a comment my dues have been paid, just waiting for my profile to be updated!
What did you use to do the cut? It's probably a little distorted right there, when you get the new one, use a small file and bevel the cut edge's outer edge and it should go easily.
ibkevin, real helpful post.
Sam
Sam
Ken,
Spot the pipe cutter in the picture (the red thing!). You can pick them up from any plumbing shop for like $4. Saves a world of hurt.......
When you're in the arch, take off the two fuel line clamps you see. IIRC, I removed the clip holding the brake pipe to the body aswell. You can then move the pipe enough to get the cutter around it. Just clamp it on, go round once, tighten, and repeat until it's cut. Should be about 5 times, and leaves you with a nice round pipe still. You may have to clean off the burrs with some sandpaper, and maybe some of the paint/coating on the pipe. Don't go too OTT though or the pipe will end up too small for the olive.
Well when I got my lines thay forgot to add the cutter, but I found one in my tool box. I couldn't get the cutter around the line from the top and at the time I couldn't get to the pass side to pull the wheel. So I did the unthinkable I stuffed the line with like 3 inches of rope and got the hack saw out. Well that still wasn't working because I couldn't get the fitting to sit flush. So now that it is warmer I pushed the car outside and did it the right way. I cut it before the bend in the firewall, now I just need a new fitting which should come in this week. Thanks for all of the feed back guys. This project lasted longer than my first 2 year membership mainly because I read a lot of horror stories about belt jobs gone bad. Truth is when I got down to it it took all of a few nights to get it done.
