What's wrong with your car?
Got Nothin'
Just list the top 3 issues you have with your car. Misery loves company.
Mine are:
Rough Idle when cold
The 60 mph shimmy
Slow A/C Leak
What are your top 3 (or more issues)?
Mine are:
The 60 mph shimmy
Slow A/C Leak
Official Bay Area Patriot
Fuse 24 Assassin
Fuse 24 Assassin
1) some burgundy spots showing in my door jambs (i will kick the PO's *** if I see him for doing such a horrid paint job for the jambs.
2) possible clutch job in less than 10,000 miles (just paranoia)
3) fuel filter needs to be changed (next payday)
1)Rubber clutch center deteriorated.
2)Fuel gauge inop.
3)odo gear is toast.
85 928
1)water pump gave up the ghost
2)driver power seat inop
3)valve covers leaking oil like a sieve
88 S4
1)Tranny won't shift above second gear.
2)Vibrations at 80+mph
3)Mysterious battery drain.
This repair season is going to be a bu$y one.
2)Fuel gauge inop.
85 928
88 S4
1. just started squirting coolant out pinhole leak from hose that enters water pump housing.
2. oil pan gasket leaking, getting onto hot exhaust/cat and causing 007-like smokescreen behind car at high rpm.
3. pass. side door handle "trigger" has to be manually pulled out before squeezing to open door from outside.
1. It's in pieces waiting for my spec 3k clutch to come in the mail (tomorrow)
2. The rear end needs to be modified so that it'll have the full adjustment range again
3. It's relativily untuned right now and running really low boost (10psi)
944:
1) Cooling fan relay shot (fans run continuously)
2) A/C system needs leak test, new receiver-drier, and charge-up
3) Cruise control isn't working (AGAIN!!!)
951:
1) A/C compressor needs replacement
2) Oil pan gasket needs replacing
3) Needs more boost
951:
3) Needs more boost
