AC tensioner please help
My damn AC tensioner broke for the 3rd time again in 2 years, i dont know why. the first time it broke i replaced it then it broke again and the compresser mounting tabs broke so had my mechanic replace both then it broke both again and it was under warentee, and now it broke again, as far as i can tell the compressor mounts arent broken again.
does abone have any ideas on whats going on???
or where i can get one tommorow, im in west los angeles now. do you think the dealer would stock this part?
thanks i advance
thanks i advance
A timely post, mine broke again on the way home from work today. I had previously had the eye ends welded while I waited for new ones from Porsche. When I went to replace them this evening I found that I have a later S2 tensioner strut with M10 eye bolts but the ones I had ordered were M8 which is what my 85 car should have according to PET.
The reason for the latest break was that the fwd comp mount bolt had come adrift. I had a similar problem to you previously in that my front mount had sheared. I had an aircraft welder weld a big chunk of aluminium & re-drilled it. Its holding up fine but I need to get some nyloc nuts to ensure the bolts don't fall out again.
Unfortunately the belt chewed through my lower toothed belt cover in a couple of spots & the belt is shot.
One tip I can offer is to loosen the mount bolts prior to adjusting the tensioner rod, if you don't this will put strain on the eye bolts which could cause them to break. Otherwise I would check the A/C comp mounts again.
i am having this problem. when i bought my 944 the a/c tensioner had snapped. leading the a/c breakits mounts and fall down. i replaced the a/c compressor and tensioner. the tensioner broke again in the same spot. so 3 times that bar has broken. WTF is up with that? i was told vibration could do it. motor mounts seem ok. but engine does vibrate when revved up past 3k. i think the coutnerweights on the engine were not calibrated correctly when the timing belt was last put on. anyone else agree?
I concour.. sounds like your balance shaft belt is out of alignment. Its not to difficult to check it yourself. put the engine at TDC and pull the top and bottom timing cover off. With the cam at TDC, the marks on the upper and lower balances shaft sprockets should be lined up with the rear timing cover.
Typically the car will shake like a washing machine with bad engine mounts.. you would defenetley know something is amiss. The vibration will smooth out as you raise RPM's. Increase vibration as you raise RPM's points towards the balance shafts.
This is a helpful picture..
Nerd Herder
My frequent AC tensioner problems/ breakage ceased when I replaced the motor mounts.. HTH.
3K rpm vibration, sounds like the balance shaft is 180 degrees out.
Change the pump every other belt change, but check it every time you have the belt off for any excess play in the drive bearing. If the pump goes bad it can either start leaking or seize up completley destroying the timing belt in the process.
