Intake manifold gasket(s)
![Unhappy](https://rennlist.com/forums/images/icons/icon9.gif)
hello all
yes, the dreaded IMG is leaking at the front cylinder. not bad,but enough to make the idle wonky. my question; how much of a PITA is the gaskets to replace?
also, go to Porsche ? or is aftermarket okay too?
thanks
Robin
![crying](https://rennlist.com/forums/graemlins/bigcry.gif)
thanks
Robin
![typing](https://rennlist.com/forums/graemlins/yltype.gif)
Not terribly hard to do. Just requires removal of the air box assembly and the fuel rail. Just get the OEM Porsche gaskets.. they arent that expensive.. i think less than $5 each. You may consider addressing the vacuum lines / hoses under the intake while you have it off.. as well as replacing the air oil seperator o-rings while your at it. All of which are not really accessable unless the intake is off.
you can order the victor reinz (factory supplier ) gaskets from a carquest I think they're 1.49 each last set I ordered. Also when in a pinch, small block chevy thermostat gaskets work exactly the same!
![Cool](https://rennlist.com/forums/images/icons/icon6.gif)
![jumper](https://rennlist.com/forums/graemlins/jumper.gif)
![evilgrin](https://rennlist.com/forums/graemlins/evilgrin.gif)
i'll have to make sure i Stroll thru the showroom!!
![w_attention](https://rennlist.com/forums/graemlins/attention_whore.gif)
