Loud bang under hood, while my head was right there... tech question...
Lifetime Member
Lifetime Member
I'm trying to figure out of my battery is getting a charge. I'm under the hood with the engine running, and revved it up a bit with the throttle. A very very loud BANG(!!!) was heard right around the air filter. The car continued to run until I could turn it off. I started it shortly after and it started normal.
Was this a backfire or is this detonation? If so... what is the "normal" or frequent cause of this on the 968 (engine)?
Thanks,
Matt
Thanks,
Matt
Campeck Rulez
i've had my car backfire through the intake before.
I thought detonation was more like popcorn or a slight bang.
did you see smoke?
it blew my j-boot off..LOL!
did you see smoke?
I've had my 944 backfire once, while revving under the hood by hand as well - I just wrote it off to a "who knows?" since I know the car's in perfect mechanical shape.
Sam
Sam
Sounds like a back fire threw the intake, It has happened to me in my 924S while I was tuning the MAF setup. You might be running a little rich, or if you where free revving it up and down and up and down you might have loaded it up with fuel and POP. But as long as its ok now, I would just keep a eye on it.
mine did the same when i put on an autothority maf and left my guru chips in w/the 3bar fpr.i thought my engine blew up and i was under the hood also.im guessing i was running toooooo rich.
When i first read the title the comment "hood shocks shot" jumped into my head.
Sorry, had to do it. probably not a problem. I go with the flooding theory.
Lifetime Member
Lifetime Member
So what I'm hearing is that it's probably OK just got a little rich? I wish I was rich. So nothing to worry about for now?
Tom, funny - actually my hood shocks are wearing down as I leave the hood up alot in the garage as I'm working on it. And you might guess it's been worked on a lot.
