Damned Blinking Airbag Light (continued)?
As I posted previously, my airbag and exclamation lights are constantly blinking after start up. I tried the reset procedure (using a stop watch for exact timing) several times, to no avail.
My mechanic who installed my new clutch had no idea, thinking maybe it was a problem with my Airbag computer.
I won't pass inspection with the stupid lights flashing, and the airbags wont deploy in this state.
What else can I look for to fix the blinking lights? Any ideas?
Andy
Andy
The blinking lights are blink codes. There is a fault in the airbag system somewhere.
I'll try to dig up the blink codes for you.
edit:
Found it on Clark's garage, but it's too long to copy & paste.
edit:
It's not blinking SOS or anything. It's constantly blinking rappidly, all the time. If you can find a fault code for that, that would rule!
Uhhh...nope. I thought Clarks just shows how to reset the lights via the wire to ground method? Are there other instructions about the blink codes?
Hmm, I believe they are mounted on the aluminum bumper behind the bumper cover, but beyond that I don't know. Hopefully somebody better versed in the airbag system can step in here?
Have you found the problem? Mine is always blinking and can not find the cause. And the diagnose...well i can not diagnose it, because there is no response from the diagnose socket.
Mine is a 964
Mine is a 964
