Best way to paint rims?
Originally Posted by AndyK
Who does powdercoating generally - not a body shop? And, when you give your rims to whoever to be powder coated, do they sand them and prep them like a standard paint prep? How do you match the center cap to the powder coated rim?
I'm getting some phone dials in need of a re-finish. Nice silver powder coat seems like a plan!
You should see the difference between PC and liquid paint under a sandblaster.... the liquid literally blows off without hesitation, while the PC takes sortof "elbow grease" if you will. Much more bead/sand blasting needed, and they may you to get it etched cause its takes such a long long time.
My "ghetto" method:
1. Remove tires from wheels
2. Clean wheels well.
3. Use scotch brite to scuff up the surface of the wheel to be painted.
4. Apply 2 light coats of primer
5. Apply 5 coats of paint.
6. Apply 8 coats of clear coat.
Yeah, some areas of the wheel will chip, but these are my track wheels, so it matters little for me.
A couple of pics of the results: (Yeah, I only painted the D-90's. Color is called Anthracite - it is a dark grey metallic finish)
-Z.
-Z.
Dont have the time, patience (or skill) to apply 15 coats of paint to 4 rims! I'd gladly pay $280 to get them nicely powder coated by a pro!
Those dark D-90's look like steel nascar rims!
Did you look up "powder coating" in the yellow pages to find where to get the job done?? And how do the center caps look powder coated...?
Originally Posted by Luis de Prat
I agree. Plus, plain paint won't hold up as well to heat and brake dust.
