Jumper? I don't even know her...(ba dum ching...)
01-19-2005, 02:26 PM
Need help with a jumper... i.e.: How to make?
Need to remove a relay and use a jumper to test.
01-19-2005, 03:15 PM
Any piece of wire will do. I use a small length of fat (think it's 12 ga.) wire as the jumper for the diagnostic port for setting idle - works fine.
01-19-2005, 04:03 PM
paper clips work good too...I was going to say it before, but I wasn't sure if it was supposed to be more complicated for some reason...But if all you have to do is jump 2 wires, then it should be pretty easy.
01-19-2005, 07:07 PM
Wax On, Wax OffRennlist Member
I used a paper clip as a fuse on my RC car a while ago...
it blew too...then I bought a new speed controller.
01-19-2005, 08:43 PM
I use them for jumping pin 14 (green wire) and any ground on an ATX pc power supply to test it sans-computer.
01-19-2005, 11:09 PM
They often have probes or clips of some type, depending on the application.
01-20-2005, 12:34 AM
Hey Big Red, Go to the frwilk.com/944dmerelay.htm web site. It is a great web site. Everything you need to know about the dme and that good ole relay.
