Brake Fluid light?
Brake Fluid light?
My brake fluid light comes on whenever I make a left turn. If I'm going straight or making a right turn it's fine. Does this mean only one side need bled or what? Please help, TIA
THe fluid light is just a fluid level sensor in the reservoir. It's probably located such that the cornering forces of left-hand corners make the fluid shift away from the level sensor.
You need to do two things:
1) Find the leak.
2) Fix the leak.
Aaron
1) Find the leak.
2) Fix the leak.
Aaron
mine used to do that until I topped it off, only ever occured when going down my friends driveway. (Very steep for 1/2 mile) Recently the oil pressure pulled that stunt and scared the crap outta me.
