is the 924S an early or late 944 NA engine?
Wax On, Wax Off
Yeah, I'm gonna adjust the idle as per azndrvr's instructions, but I'm not sure if I have an early or late 944 engine...
the engine itself is a 1988 924S engine, however, all of the components are from a 1987 924S...DME, all connections, sensors, etc.
Tom the idle can be adjusted somewhat. There is a adjustment screw located on the throttle body-8mm IIRC, start the engine and loosen the nut and turn CCW to lower CW to raise....IIRC. Be sure not to adjust this screw too much, turn 1/8th at a time till the desired RPM. I was running 1200 and now 975+ after this minor adjustment.
