front end seals compatibilitititlity
i am about to put this stuff together, with much needed help from nine-44 (andy kihm). if anyone wants to join in on "THE WINTER FREEZE OIL SEAL AND BELT EXTRAVAGANZA"tm, you are more than welcome. you can stay at my apartment, and we will freeze out in pickerington ohio. all peopel feeling like it in ohio, columbus, california, cincinatticncncncnc....are more than welcome to freeze. the expected dates are friday night(14th[parties and games and cruise is cancelled]) saturday(15th[car show, bake off, and dyno sessions cancelled]) and if need be, sunday(16th[bullriding, dance off, and swimwear contest cancelled]) sorry about the cancellations. all other activities are still going on.....(reseal and belts). the name of the extravaganza is still under construction. you can live anywhere and come hang out....not just ohio or california....if you need to fly in from prague, please let me know ahead of time so i can pick you up at the airport.
Kenny:
Here is a list I have come up with over the years. Pick and choose what you need. This is only the front engine seals.
944 8 VALVE FRONT ENGINE SEALS, BELTS & WATER PUMP PARTS LIST
From engine # 43F 06995 (1985) thru 1986 8 valve engines
Camshaft
1 each O-ring 999.701.602.40
1 each Woodruff key (optional) 900.117.045.00
1 each O-ring (onion skin) 944.105.321.00
1 each Spacer 928.105.139.04
1 each Seal 999.113.349.40
1 each Bolt (optional) 999.510.022.08
1 each Toothed roller 944.105.027.04
1 each Stud 944.102.216.01
1 each Nut 944.102.243.00
1 each Smooth roller (for updated pump) 944.105.241.03
1 each Rubber seal 928.105.184.00
1 each Belt 944.105.157.04
Crankshaft
1 each Seal 999.113.331.40
1 each Sleeve (oil pump drive) 944.107.161.02
1 each O-ring 999.707.283.40
1 each Woodruff key (optional) 900.117.036.00
Balance shafts
1 each Seal (upper, cw rotation) 999.113.282.40
1 each Seal (lower, ccw rotation) 999.113.281.40
2 each Spacer 928.105.139.02
2 each O-ring (same as cam) 944.105.321.00
2 each O-ring 999.701.652.40
2 each Woodruff key (optional) N 012.708.2
1 each Tensioner roller 944.102.025.07
1 each Smooth roller 944.102.277.06
1 each Belt 944.102.219.02
Water pump
1 each Water Pump 951.106.021.10
1 each Gasket 944.106.132.04
1 each Block off plate 944.106.313.00
2 each Bolt 6 x 20mm N .014.704.1
2 each Washer N .011.524.7
1 each Thermostat 944.106.019.00
1 each Support Washer 900.234.160.00
1 each T-stat O-ring 944.106.929.08
1 each Guard rail (for updated pump) 944.105.210.01
2 each Lock nuts (for guard rail) 999.084.092.02
Camshaft
Crankshaft
Balance shafts
Water pump
thank you for that. i bought some stuff at p3elican that i couldnt egt through my job, but andy ended up using some of his extras cause i guess that napa parts are junk. lots of thanks goes to andy for basically working on my car......my goal is to have it running by the weekend, but i wont have money for the alignment....so it wont be driveable.
