New Flywheel!!!
New Flywheel!!!
My flywheel from Powerhaus had a white residue that I tried to remove with brake cleaner and Actone but it still would not disappear. What are you suppose to use to clean the flywheel?
Thanks,
David
Thanks,
David
now that's a beauty. is it a lightweight? i ordered one from broadfoot - just waiting for it to arrive. where are the flywheel teeth? how does the starter engage the flywheel?
Not sure.. I purchased the clutch as a kit which includes the KEP pressure plate, 930 clutch disc, lightened flywheel, release bearing, rear main seal and other associated hardware. Not cheap but quality and rep are very good $1600.
Originally Posted by TheStig
why do you want to clean it any further? Unless you're gonna serve Thanksgiving Turkey on it then I see why
Originally Posted by dualblade
it's only the s and s2 flywheels that have teeth, and they're for timing only. the ring gear on the pressure plate is what the starter turns
The new flywheel I just put on my 951 had that same "residue". Looks like an acid etch of some kind, but it is smooth. I just did as you did (actually 2Tight did it for me :-) ) - clean it with brake
cleaner and its ready to install.
Did you experience any chatter or problems as a result?
Thanks!
Thanks!
Thanks!
