HELP! removing sensors from bracket
Hello all,
Have all ready to go (after replacing clutch assembly) on our '86 944...except the sensors and bracket.
The sequence of assembly appears to be the bracket and then the sensors.
The problem, however, is that I can't get the sensors out--both are so tight that I can hardly turn them (even using penetrating oil).
Any ideas as to what I can do?
I'd love to get this thing off the jack stands over this holiday!
Assistance will be greatly appreciated!!
Thanx in advance,
Bruce Garrett
Leander, TX (Austin area)
Thanx in advance,
Bruce Garrett
Since you said the clutch work is done did you remove the sensor bracket with sensors as one unit?
Mine were really caked up from old oil leaks; I just kept turning and pulling and they finally came out. You can't hurt the actual metal sensor but the plastic housings will break if you force them with vise grips, etc.
basically you just have to try your best and take your time taking it out...it needs a lot of nudging and turning and gripping. good luck with it though...hey at least you didn't have trouble with the starter bolts! or did you?
Thanx for the replies--
The clutch job went smoothly; just had a bit of trouble with the clutch fork rod but after some penetrating oil sprayed through the clutch inspection hole, it came out.
Regarding those pesky sensors, having never seen one before, do they have o-rings for moisture proofing? Could this be the reason they are so tight? Can I force them out by pushing on the bottom with a vise? The cylindrical pieces don't turn with the tops....
Thanx,
Bruce Garrett
Thanx,
Bruce Garrett
I ended up breaking the bracket off with a crowbar. Be careful doing this, as bracket shrapnel can fall into the sensor hole.... since youre doing a clutch job it shouldnt really matter you can get them back out, but be careful
While there is not an o-ring, they are very tight. If you have the bracket out you should be able to push them out from the bottom.
If the bracket is out, I hope you marked the location, as the sensors have to be gapped .8mm from the flywheel for they to work.
The sensors do tend to get a little dry and brittle over time, and the wire can break.
They have a small O-ring between the metal and plastic parts. The bracket is a soft aluminum, it will break if you push too hard on the sensors. If the top is turning without the bottom moving, the sensor is damaged goods. I would remove the bracket and drive them out. It doesn't require a lot of force to remove them once the bracket is removed and you can get to everything.
Originally Posted by beab951
...If the top is turning without the bottom moving, the sensor is damaged goods...
Well, having taken out over 200 of these things, I can say that at this point, if they seem to be stuck, you have about a ten percent chance of getting them out without breaking them.
If they have been previously coated with antiseize compound, and if the holes in the brackets have been relieved (made a bit larger), then you have a better chance.
My clutch job estimates always include the cost of new flywheel sensors.
gb
gb
