easy way to get bearings out of the clutch fork (nickel and c clamp)
turns out that a nickel is the perfect size to be bigger than the bearings but smaller than the hole in the clutch fork. i had figured this out back when i was doing my clutch, but i know a couple of other people are doing clutch jobs now and thougth this might help them out. not everyone has a press in their homes and this was is easier than hammering on bearings for a while. you'll need 7 or 8 nickels to pull this off. just turn the c clamp until the bearing pops out a bit and then keep stacking nickels until the bearing comes out
also, if you don't feel like using nickels, i'm guessing a socket would work as well. i haven't looked, but i'm guessing there's a socket about the size of a nickel that could be used in the same way. i just thought of this because then you wouldn't have to stack nickels
I clamped it with a large socket on the backside of the bearing, so I didn't apply clamping force across the span of both arms. Probably won't cause any damage your way, but I didn't want to risk a tight bearing stressing the cast arm.
Sam
Sam
Sam
Sam
