Radio install question
I need 4 wires for my radio:
500mA / hot all the time - will tap into clock power
500mA / lights for radio - will tap into one of the many dash lighting wires... probably ashtray light
ground - easy, just run one to an existing ground point
the problem:
10A / main power for the radio
I'm having problems finding a wire that's on a fuse at least that high since it seems like almost everything in there uses an 8A. Anyone know of somewhere I could tap into without blowing anything? The instruction manual says that fusebox location 5 has a 16A fuse in it and that nothing is connected; is this right? Any way to get at it without making a huge mess of everything?
the problem:
How about the stock power antenna? I had planned on replacing it with one in a local yard if they don't want an arm and a leg for it. Mine has a broken mast, I wish I could just replace that part but then again I don't know what shape the rest of the assembly is in. I assumed that it drew power from another source and somehow went up when the radio is turned on.
Edit: I don't know what the PO did with the radio wiring, my guess is he cut it somewhere that I can't see since none of the wires have power or are grounded. He also cut the wires at the radio harness. The front speaker wires are ok at least... don't know about the rear ones.
Will the stereo blow the fuse if I have it on while powering something (like an MP3 player) from the lighter? The label on the fuse holder on the radio calls for a 10A fuse, but I'm not sure how much these head units typically draw.
No relay.
You should be fine unless you turn it all the way up.
You could just run a 14 gauge wire over to the 16A un-used fuse, and just wire into the back of the fuse panel. I don't know what the back of a 924's fuse panel looks like, so I'm no help there.
Originally Posted by RMills944
Are the stock radio wires not there or did I just miss why you aren't using them?
If you are using stock wiring, then just do a search for "radio wire colors"
It's probably not the same for the 924S, but AFAIK all late 944s had the option for an equalizer/amp from the factory and even the cars without the amp have a heavy wire there to supply it. I used this wire for my 60X4 amp alpine unit and haven't blown any fuses. Sorry if this doesn't help.
Did you look at the back of the head unit to see what power it needs? The 8 fuse on the stock wire may be big enough. If you hooked up to that, the worse that would happen is that you would blow the 8A fuse. And its already switched like it should be.
Do your self a favor - find the previous owner and smack him upside the head with the radio while letting him know he's a dumbass!
Update: the two larger wires at the radio are yellow and brown/yellow stripe. I can see the yellow one just behind its fuse and it has power there when the ignition is on, but not at the radio. Maybe it's broken somewhere? It's next to impossible to trace it so if this is the main power to the radio I'm just splicing in a new section unless someone knows where it runs.
The other one is brown with a yellow stripe. No clue where this one goes. Does it have something to do with the power antenna? The antenna I have no idea how to factor in. How does this get wired into the system?
