aligning the motor
11-05-2004, 03:38 PM
aligning the motor
hey I'm having trouble getting the motor to slide onto the drive shaft, I aligned the clutch and everything... any advice?
11-05-2004, 04:05 PM
You gotta make sure the hole is level, that's about all there is to it. What exactly are you doing?
11-05-2004, 04:08 PM
I'm putting a new motor in my car. its not going very well.
11-05-2004, 04:11 PM
Which way are you going top or bottom?
11-05-2004, 04:12 PM
11-05-2004, 04:18 PM
I have done two from the bottom, used an engine host to lift it up and then a floor jack to help level it.
11-05-2004, 04:24 PM
AddictRennlist Member
Make sure the driveshaft splines and nub for the pilot bearing are good and clean, then apply a little anti-size compound on it. Should slip right in if you have it level. If the car and motor are well supported, some minor shaking is allowed.
11-05-2004, 05:17 PM
alright I'll give it another shot tommorow, thanks for the help, wish you were closer to come and give me a hand!
11-05-2004, 05:24 PM
AddictRennlist Lifetime Member
Wiggle, wiggle, wiggle... and then it will just slide into place. It took us a few minutes but I'm sure you'll get it.
11-05-2004, 06:29 PM
it's possible that the splines are butting up against each other. try rotating either the engine or the trans, with it in gear, and see if that helps.
11-05-2004, 07:03 PM
One trick is to measure the gap between the torque-tube and bellhousing at all four corners. Then you'll know which way to angle the engine.
11-05-2004, 11:39 PM
well someone that actually knows exactly what they are doing is comming up tommorow which is gonna be awesome... hopefully all goes well, I'll let you guys know!
11-05-2004, 11:41 PM
Nerd HerderRennlist Member
Mark and Danno have the right approach.. it takes patience and finesse.
11-05-2004, 11:54 PM
Haha, i shook my engine back and forth, while it was on the lift, as hard as i could and it went in.
11-07-2004, 10:52 AM
well 5 hours of wiggling and shaking to no avail... the splines went in fine but there is still an inch left... all out of ideas and the motor already fell on my leg once while I was under it.... discouraged.
