Swapping LSD in 944 Tranny
Question: How hard is it to remove a Limited SLip Differential from a 1986 944 tranny and install it in a 1988 non LSD tranny?
Any ideas where I might be able to find instructions?? or is this strictly a Tranny shop procedure....
Thanks for any and all advice.....
I made dummy bearings 10 thou smaller than the new ones to help set the preload, made setting the DP angles much easier, on the whole the job is about a 6/10. I found it hard to get the rear plug for the box so I spun an alloy one up to take it's place but I guess you could find a core plug to do the same. The bearings I got from Porsche and on the way back from picking them up I stopped in a bearing traders and they had the exact same bearings on the shelf as it's a fairly common size, for less than a quarter of the price (you should change the bearings if your changing the diff), however that said its a walk in the park to change the whole transaxle in comparison, I'm guessing it's a turbo box going in an NA so you want to keep the original gearing.
Don't you just hate that, now I find out, never mind, at the time (3 am) teh easiest solution was to make one, but I'm off to ebay to get a few more, I'm hoping not to use them.
Hey Adie,
Speaking of transmissions, I see that there are a few trans experts over there on the 560sec board. Any chance that I am able to register and post there? I'd like to be able to ask some questions and also maybe share a little info that I have in that department. If not, that's OK too.
Originally Posted by tifosiman
Hey Adie,
I said so.
Doug
Thanks Doug!
Patrat, it's the big black end plug on the back of the trans housing. The only way to get it out is to put a hole into it and pry it out. Once there is a hole, the integrity is compromised. I imagine one could find a way to seal up the hole and re-use it, but I would prefer to just install a new one. Especially on something as expensive as a trans rebuild.
