Dealer is trying to rip me off!
The dealer who did my water pump/timing belt change charged me for three rollers.
944-105-273-02
944-102-277-06
944-105-241-03
and two tensioners
944-105-027-04
944-102-025-07
There's only two rollers right? That first one (944-105-273-02) is for the old water pump. He's telling me the new water pump needs an additional roller. I asked him where that new roller would mount. He had no answer.
Should I tell him he's full of crap or am I wrong somehow?
944-105-273-02
944-102-277-06
944-105-241-03
and two tensioners
944-105-027-04
944-102-025-07
Here's the cheat sheet I use:
944.102.025.07 Balance Shaft Tensioner 83-95 All
944.102.219.04 Balance Shaft Belt 83-95 All,
944.105.273.02 Timing Belt Roller, 32mm (See Note 1) 83-86
944.105.241.03 Timing Belt Roller, 46.2mm Dia. (see note 2,3) 87-95 All
944.105.157.04 Timing Belt 83-89 8V
944.105.323.02 Timing Belt 944S, S2, 968 All
944.105.027.04 Timing Belt Tensioner 944 83-86; 86 944 Turbo; 924S 86-87
944.105.631.04 Timing Belt Roller on Tensioner (See Note: 2)87-89 944, 87-89 944T; 87-88 924S
944.105.631.10 Timing Belt Roller on Tensioner 944S, S2, 968 All
944.102.277.06 Balance Shaft Roller 83-95 All
Note 1: Also fits early 87 924S up to engine # 43H01919(Manual Trans) & 43H60384 (Auto Trans)
Note 2: Also fits early 87 924S from engine # 43H01920(Manual Trans) & 43H60385 (Auto Trans)
Note 3: Early cars that have been updated to the later style waterpump with belt guard rail will this roller
Your Porsche Parts Superstore
Parts | Tech-Session | Facebook | Youtube
Jason Burkett
Paragon Products - Porsche Parts & Accessories*- 800.200.9366
Tech Session - Porsche Tech & Info*- 361.289.8834
jason@paragon-products.com
Jason Burkett
Well, I went over to the dealer and even talked to the mechanic who did the work. He insists that the new style water pump requires an additional roller 944-105-241-03 which is attached to the pump itself.
I guess the only way to find out for sure is to pull the covers this weekend and see what I've got. If there's only two rollers in there, look out!
Hahahahaha, that guy is full of crap.
I wonder where he installed the 3rd roller!
His story might have a tiny bit of truth to it, I believe when you update the waterpump, you have to use the newer timing belt roller, but you can't install both.
Originally Posted by Zero10
Not possible.
Only the first timing belt tensioner should have been used.
If they billed you for both, go back there and get the other one! =)
Or get your money back.
944.105.273.02 and 944.105.241.03 are mutually exclusive.
Originally Posted by theedge
Is he talking about upgrading an older pump to the new spec?
Originally Posted by Rich Sandor
How much is the one roller?
Originally Posted by StoogeMoe
He insists both are in there.
I don't know if it's still accurate but last I heard, list price for 944.105.273.02 is $29.63 and list for 944.105.241.03 is $42.84. did they charge you for any other parts to convert to the new style (little metal fence thingy, etc)?
Those prices are almost right on. The guide bar was included with the pump. I took a diagram of the balance/timing belt and had him draw where this new roller was placed. He drew it between the water pump pulley and the timing belt tensioner. I don't think it could physically fit in there.
There isn't any kind of roller on the guide bar is there? It's just a hunk of metal, right?
Step 1: Announce the dealership's name in first post, LIKE THIS.
Step 2: Crosspost to other forums.
Step 3: Obtain names and email addresses of management at dealership.
Step 4: Forward them a link to this thread. Enjoy the entertainment that $30 bought you.
Step 5: Forget about it and move on. $30 is not worth your time and agony.
