How to remove A pillar?
Rocket Scientist
Hey, I tried to take the A pillar out on my car. I removed the three screws and I couldnt get it out. Are there more screws behind the dash that I need to remove? Or do I just pry it up and it will come out? I didt want to break anything since that has been my history lately, so I didnt force anything. Thanks
You just need to pry it out. Start at the bottom. It may help to loosen or remove the sun visor because the top of the A-pillar piece is clamped under the roof liner and you'll need to provide some wiggle room around the liner/visor area.
Just a car guy
If you really want to remove the A-pillar - a sawz-all will do the trick. If all you are trying to remove is the trim piece on the A-pillar, you can try the method listed above.
Hope this helps...
Hope this helps...
