Changing O2 Sensor
Yep...
Take off the exaust (easy)
If you don't need the o2 sensor and got a new one..
Do this...
PB-blaster/liquid wrench the crap out of it! and try to use a correct size socket with a breakerbar and get a 6foot metal pole and break it off... If no right sized socket then invest in a pipewrench and put the pole over that and break it loose! (hardest part is getting the old O2 sensor out)
Then just put the new one in (not hard) and bolt up exaust and hook the 02 sensor back in and its as good as new!
Do this...
Mine was in there pretty good too. I bought a really long 1/2 extension and a flex joint...I already had the magic socket with the cut-out (same one you use for the top nuts on the front struts) and cranked it from above with a half inch breaker bar. If you have the replacement with the wiring or if you're adapting the generic sensor you can use a deep socket on it after cutting the wire off...
The new O2 sensor solved a lot of problems....even made my gas and oil gauges more accurate!! Don't ask me why....
I changed 3 of them and the old ones just came out. Used an end wrench.
Get the bosch generic O2 sensor and wire it in. Thy come with some nice water tight screw in connectors if I remember correctly.
