No Brake Fluid On One Side
Hey guys quick question. I was bleeding my brakes the other day as the pedal was firm but not going all the way up. I noticed I could bleed the passenger and rear passenger side but both driver and driver rear had no fluid really come out. Only thing I can figure is a blockage or build up in the line, but are even running off the same lines? I would think front and rears would be separate.
the front calipers each have their own hard line off the master
the rear calipers have 1 line coming off the master that Tees into 2 sides at the back of the car.
so if you were getting fluid at Right Rear you should be getting some at left rear.
and the 2 front takeoffs from the MC are next to eachother so fluid should be going to both simultaneously unless there is a blockage somewhere.
The following 2 users liked this post by V2Rocket:
Tiger03447 (11-16-2022),
walfreyydo (11-16-2022)
tempest411 (11-20-2022)
