Fan Control Knob Not Working
Fan Control **** Not Working
Hi everyone, my fan **** has recently stopped working on my 86 951. No matter what setting it's on, no air blows through. There was an instance a couple days ago where the air started coming out, but it seems as if it's bit the dust for good now. Where is a good place to start in diagnosing this? All help is appreciated!
That happened to me once. I unplugged the wires from the switch. They didn't look dirty at all. I sanded them down and plugged the wires back on. That fixed it. Been working fine for about 5 years now. Good luck.
thanks for the thread, my **** does not click, will be pulling it apart soon. thanks.
EliteThink (07-06-2022)
If it only runs at high, it is the fan resistor.
http://944time.com/porsche/944-fan-speed-resistor.php
If it doesn't run at all, I would check the fuse. But of course it is never the fuse. Because that would be too easy!
Check voltage to the fan.
EliteThink (07-07-2022)
I've actually had the fan control **** break so that I only had high blower, however cleaning the little temp breaker(s) in the HVAC fan resistor unit (pictured above) is a great thing to do. I put a drop of acid on the contacts with them held open and then rinsed and dried. The 968 has one of these and the 944/2 has a pair, visible when the resistor assembly is easily lifted out of the HVAC air intake.
