Timing belt tool
Timing belt tool
I bought a 1986 944 last October with my father. Currently it's in the garage for the winter and we were planning on doing the timing belt, pulleys, and water pump sometime next month before the snow melts to get it fully road worthy for the spring. From reading the forums and having never done a timing belt change before, I realize I need either the stock timing belt tensioner tool or the arnnworx tool because I don't not trust myself for the twist method. But it is hard to rationalize spending $200 on a tool I will use once every 3 years. Does anyone have one that I can rent from them or work something out with? I live in Boston but the car is located with my father in Central Maine so anywhere in between I am willing to travel to. Thanks in advance!
Which tool you meaning. The one for the tension? If so just use the twist method. Put the belt on, tighten rotate counter clock wise the 5 degrees and then forward a full rotation. Then you take the longest section and twist the belt with your fingers I believe about 90 degrees. If its firm then you should be good. Too lose or too tight then retension. Watch Vans videos, they are a huge help.
Here's all 3 videos.
https://youtu.be/nqc0mm-7ukY
https://youtu.be/K8T1SPook_k
https://youtu.be/UvzZ2objumY
The following 2 users liked this post by CyCloNe!:
Duhvinci (02-05-2022),
Zirconocene (02-06-2022)
I have a 9201 but think the twist method is fine. You can also see if the water pump pulley can just be turned by hand (it will be hard) while at TDC and having rotated the engine a few times by hand.
More critical IMO is re-tension as the belts get very loose after they run in and mate with the sprockets.
Balance belt sprocket alignment is critical and often gotten wrong.
Balance tensioner turned the wrong way likewise.
Having suffered a snapped timing belt after using the twist method (can’t say this was necessarily the cause), I am a fan of using the tool, and would encourage you to just get one, especially if you haven’t been doing the twist method for years.
Not all hands and fingers were created equal…
tempest411 (12-07-2023)
I just went through this thought process myself. The Arnnworx kit is more expensive then the belt kit I need to put on, is it really worth it??
Let me tell you, as someone who did his first timing belt a few weeks ago, it is worth every darn penny. I would buy it again without a second thought. The added confidence that the tool gave me to get the work done made it so much easier to do the job. Moreover, you will need that tool more than once every 3 years, I can almost promise you. Cam Tower has to come off? You need to re-tension the belts. Water Pump? Belts are coming off. You definitely need the flywheel lock and at least the pin wrench to do the job anyway, so why not do it with the proper tools?
Just one man's opinion, but I love my set. Plus, if you ever sell the car, you will likely get your money back on the tool.
The following 4 users liked this post by SC924S:
The flat offset wrenches are great, as is the pin wrench. But I use the twist method for tension.
The Arnnworx tool is worth every penny.
I have used it for 3 TB changes and had it upgraded to the current version prior to the most recent one. It's a very small price to know the TB/BS belts are accurately tensioned.
Bruce has great videos, great customer service, he seems like a stand up guy. I'm thankful he spent his time to develop this tool so we don't have to buy the P9201, that is expensive!!
Will you be changing the rollers and seals? If so, esp. the seals, you should read up and get a couple more tools before starting. Getting hung up on a missing tool the day of working means cutting corners, frustration, mistakes. For example, a new or good condition triple-square socket is a must for the cam gear... a seal puller.. small gear / pulley puller.. stuff like this.
I remember going to do just the belt and water pump once... not changing crank seal so no need to remove the crank gear, right? Wrong. The rear of the timing belt cover needs to come off on mine.. but it can't without removing the crank gear. Nobody mentioned this lol! That hung me up something silly... nevermind re-torquing the bolt needs a large torque wrench that can measure the amount needed.
