New Lifters - only Genuine Porsche
Here is a lifter
If you look at the center section it is held in by four stakes. These have to be cut in order to disassemble the lifter. Then four new ones have to be hammered into the lifter to keep the center section in. 944online seems to have a good reputation as a vendor for our cars, never hear bad things. However, they sell parts for the most part. I am with Nowanker in thinking the amount of tools, time, parts and skill needed to disassemble and rebuild these properly could never be profitable. If these lifters came apart easily like many other lifters, I could imagine a "refresh" would be possible, but not a proper "rebuild". A lot of companies "rebuild" things, some do it right and some do not. Half shafts come to mind as a recent topic on this forum. Do a search and see how happy people are who have bought rebuilt axles recently.
A member here, Van, has a video on YT where he cuts a lifter in half. If you are interested in seeing the inside of a lifter it is worth watching.
Sorry about the bad math, was thinking 8 cylinder not 8 valve!
Out of curiosity, Did RS Barn also recommend new valve springs? To me it would be strange for them to recommend you replace good lifters with new ones but not recommend new valve springs to replace the bad valve springs (if they are original they are bad - from day one they get softer and softer. 30+years later...) It would be interesting to know what springs they recommend, along with 'seat' and 'over the nose' pressure. I do not know anything about the grind of their cams and if they require more pressure to keep the valves from floating.
Here is a lifter
If you could take a picture when they arrive it would be good to see whether they were actually disassembled or just thrown into a ultrasonic cleaner.
It will also be interesting to see if they are hard or soft.
When I refreshed my engine, like I said earlier, half my lifters were soft and the other half hard. I bought the engine without hearing it run so I did not know if the lifters were good or not. I stored them in containers filled with Marvel Mystery Oil or ATF or a combination of both, do not remember exactly. Since I was unfamiliar with lifters I thought the soft ones were bad. I tried "pumping" them up with the button. It did not work, mainly because the button is not a pump!!! In my mind if they did not pump up they were bad. I then went down the rabbit hole researching and learning about lifters. As I have stated, I ended up ignoring all the internet people (like me!) and listened to the manufacturer who ended up being right.
And what did the manufacturer actually say, I think I missed that?
I see this but can't really pull anything from it..."I listened to the person that MAKES lifters. It turns out he was right. ALL my lifters work perfectly, the soft ones and the hard. Go figure, the manufacturer knows more then random internet people."
The following 2 users liked this post by SamGrant951:
fejjj (12-23-2021),
Jay Wellwood (12-22-2021)
As far as telling if they are good or bad....I have heard people say if the button is soft they are good. I have also heard people say if the button is hard it is good. I have heard people switch from hard to soft as good and vice versa. The only person who I believe was someone who was a rep for a lifter manufacturer. His advice was it does not matter if the button is hard or soft - the only way to tell is to install them and see if they work.
SamGrant951 (12-27-2021)
