New Lifters - only Genuine Porsche
Hi all, I just installed a new cam from RS Barn (from his last batch) and it is suggested that I run new Lifters with the cam. I looked them up for my 84' 944 8v and they are on pelican for $91. This is pretty steep, is there any other suppliers that I am missing that provides quality lifters at a cheaper price?
INA is the brand you are looking for.
What's the factory part # to save me some time.
Or, look here - https://www.eeuroparts.com/Parts/184...er-4200010100/
The last time I saw 8V lifters offered they were a LOT more than $81.00. Thetr are aparrently some options on the 16V models, but nothing on the 8V models...Not including Lindsey Racing's mechanical lifter conversion.
If your lifters are good why replace them? If you research lifters you will find a lot of people saying the new lifters are made differently. They say they wear out very fast. Is it true? I have no clue, but there are a lot of threads about the inferiority of the new lifters.
As far as telling if they are good or bad....I have heard people say if the button is soft they are good. I have also heard people say if the button is hard it is good. I have heard people switch from hard to soft as good and vice versa. The only person who I believe was someone who was a rep for a lifter manufacturer. His advice was it does not matter if the button is hard or soft - the only way to tell is to install them and see if they work.
Good luck on your decision.
The button should be hard, and it should compress under the load of the valve springs to release oil ( which is around 90-100lbs I think). So given that, you shouldnt be able to move the button with anything less than your upper body, and even then, it shouldn't compress much.
Go ahead and spend the $1500 on new lifters. If you want to do things right do not bother with "rebuilt" lifters, these really are not meant to be "rebuilt" like some lifters that come apart easily.
You can absolutely rebuild lifters, they are mechanical and anything that is mechanical can be "rebuilt" (or at least in my opinion).
From: Formerly the DPRK, now seeking political asylum in Oregon
I'd love to see the process on that.
Regrind the wear surface? Might have a slightly convex surface to promote rotation (Domestic ones do...)
Re harden it after grinding?
Disassemble the piston, spring and check ball? Check piston-bore clearance? Replace anything worn? Test the spring, replace if it's weak?
Do anything remotely like that, and still make a profit selling them?
I'll pass.
They used to sell 'Rebuilt' spark plugs, too...
I'll pass.
