Where does this vaccum line go???
Lifetime Member
Lifetime Member
![](http://forums.rennlist.com/upload/17368041605_0_1.jpg)
I've got the rest of the lines hooked up, but as far as I can tell this one doesn't go anywhere (I'm sure that's incorrect, obviously). The only problem is, the 968 schematics don't show this part, it only shows the valve (top of picture).
What is this part and where does this vaccum line go to on the 944, and more specifically where does it go on the 968?
Thanks,
Matt
Lifetime Member
Lifetime Member
Are you able to snap a quick picture? The 968 is different and I don't recall seeing that slot on the schematics or on the actual intake.
Thanks,
Matt
Thanks,
Matt
Lifetime Member
Lifetime Member
Unfortunately I am not near the car. I just got back from Raleigh where the car is and I don't have it in front of me to look at. Maybe a 968 Rennlister can help?
-Matt
-Matt
The line runs to the thermovalve on the 951, and then from the thermo valve to the throttle body. Thermovalve has two nipples, located under the rear part of the intake.
Lifetime Member
Lifetime Member
Well.... the 968 fuel rail is different. I'll figure it out, thought maybe it was something easy.
I can probably use one of the "Y" connectors to splice it into the intake.
