seals or rings?
ok people, my car smokes a little. has about 120,000 miles. what normally goes first? rings or oil seals? meaning valve stem seals. and......what happened to my posts on my car for sale? cant bring them up in search either.
try the classifieds.... oh wait you have to be a member.
i'd suspect valve seals before rings. on the other hand you say its a beater and you dont know the previous history of the engine, so it could be rings as well. i say just drive it.
-Mike-
-Mike-
I have an 87 S with 123,000 and I am getting black smoke under heavy acceleration. It has been suggeted that it is the fuel preasure regulator and I am running super rich. Now when the car does smoke, I can tell as the engine almost seems to knock under load. Also in cold weather say under 40 degrees. the car pulls MUCH stronger. Hence the belief that the fuel preesure regulator is bad. Uhhh ohhh leaking rings is bad....
IPSC
IPSC
Ah yes... I should have asked what color the smoke is.
I was talking about blue/grey smoke from oil.
If it's black, then you're getting too much fuel. Could be DME temp sensor, or FPR, or a couple other things...
well, mine is blue white........my first car was a heavy smoker(about 4 packs a day!!!hiyo!!!) so i definitly know oil smoke. whats a rough idea of engine cost? just something to go by....and maybe i can sell this one to someone wanting to beef one up? i dont know.
IPSC
IPSC
Kenny, what weight oil are you running? Thicker may help or try adding Lucas oil additive. If it smokes while driving it doesn't sound like seals though.
The Hoffinator
blue smoke? how much oil do you go through?
ok try this.. drain your synthetic, and put in marvel mystery oil for a couple hundred miles. sometimes thats been known to help with rings and other stuff, and get things to seal back up. if marvel mystery oil dosent do anything.. youre ****ed.
me bumper and rear is black also with little spots that look like they are wet all the time. i used to run 10w30 but switched to straight 30. i go through maybe a quart every 2 weeks.
I have a new FPR regulator on the way from EBS. I paln to put it in this week. How big of a project is this anyway?
IPSC
IPSC
~Brett
It's pretty easy, I did mine in under 30 minutes while holding a flashlight with my shoulder. You'll likely have to raise the rear of the fuel rail to get to the bottom bolt.
Maybe one beer if you stretch it out.
