Help please with broken motor mounts
Hi
i bought again my ex 924 1980 euro that I sold in 2007
found that the motor mounts are broken and that I need new ones, but Porsche doesnt build them no.more,what brand can I Buy to replace them
Thanks for the help
Henry
Thanks for the help
Henry
Here you go (no affiliation): https://www.paragon-products.com/Por...375.042.04.htm
Vertex and 944online also likely have options for you, if you want to explore those vendors. I don't know what shipping is to Argentina but it sounds like it will be worth it.
Cheers
Cheers
Rainman
Cheers
Cheers
There is an aftermarket option available:
https://www.ebay.com/itm/Porsche-924...-/380641293792
@V2Rocket : Whoops! Apologies OP. I got to that link by following things from the 924 section of Paragon and didn't notice that it was only for the 924S (which may still be incorrect, I have next to no knowledge about this series of cars).
Good luck
Good luck
OP has an old 924 which uses a completely different engine mount than the 944 series; even the crossmember is different.
