Eternal 968 flywheel dilemma- anybody used 25lb Spec steel unit?
Almost Addicted
DMF seems to be making noises upon clutch pedal release, and clutch needs attention anyway. I'm not spending $2k or whatever on one of the few OEM DMFs available. I've read post after post about the vibrations and rattling from the 13lb fidanza unit, and that the 18lb RS barn isn't as bad, but they are OOS anyway. What I haven't found are any reviews for the 25 lb Spec Steel flywheel. It's still 7lb lighter than stock, so maybe there will even be a slight performance improvement, but really I want drivability and reliability. My car has too many miles to introduce anything that's going to unduly accelerate wear. So... Anyone care to chime in with experience or even theoretical postulations?
Rainman
Solid flywheel paired with a new RSBarn harmonic damper (crank pulley) and you'll be good to go.
I have a 9lb aluminum FW on my 2.9L paired with the RSBarn damper and it is smooth at all RPM.
Almost Addicted
Hey Spencer, I assume the increased stroke to get to 2.9 puts your engine in the same type of situation as the 3.0 with regard to vibration? I didn't know that there was an aftermarket harmonic balancer... Last thing I read on it said that the S2 balancers were NLA, so that is something to look into. Thanks!
Rainman
Indeed, and if they didn't cost $2000+, it would be a no brainier. Just can't swing it... Or I guess I could if I had to, just can't stomach it.
http://www.rsbarn.com/catalog/index....roducts_id=103
alex (11-17-2020)
Contact Brandon @California Clutch
https://californiaclutch.com/?v=f24485ae434a
CC machined a 944 light weight steel flywheel
@s85b50 : It won't make a difference because of the transaxle, but I'm surprised about your M3s. My E60 M5, even with the clutch at the end of its life (and presumably the dual mass flywheel, as well) is OK at idle. Getting into first is juddery, but not idle. Maybe I didn't understand what LTW means.
Cheers
Cheers
Cheers
Cheers
Rainman
My 9lb aluminum Spec flywheel with steel insert doesn't have any judder - it's quite smooth-engaging, actually. It is mated to a standard 944 NA Sachs clutch kit.
Rainman
944 solid FW with the harmonic damper on the front of the crank does not rattle or anything like that.
This is how it sounds. Not my video, but very similar. Apparently the stock dual mass flywheel eliminates this completely with BMW's NVH design, so I was wondering if 944 design was similar to this.
DMF or not, it shouldn't sound like that on the 944. At least, it sure doesn't on my car, which did not benefit from the 968 DMF.
