Glove compartment light bulb
Does anyone know what type of bulb the glovebox light uses? Mine is missing the bulb and the Sylvania computer at Pep Boys only lists the bulbs for the ashtray and the luggage compartment/headliner lights.
I tried to buy one of those bulbs at my local Porsche dealer but they said that it only came as the whole assembly so on the way home I stopped in at an auto electrical shop and showed them the old bulb & presto, new bulb for $1.
Why don't you just drive the car to the auto parts store, pull the bulb there in the parking lot, walk in and compare with bulbs on the shelf, and grab the one that matches? It's a common bulb, any Autozone has it.
Sam
Sam
Sam
Sam
Thanks Mate, I didn't have a bulb to compare at the store either.
PCMAX, weren't you the one that had the timing belt go just after purchase? How did that turn out?
hey eyal, it is a bulb down there. you have to take off either the inside of teh cassete holder or pop out the ash tray to see it, i dont remember exactly, i just remember seeing the bulb, on the end of a wire
You are probably not going to be able to find that Narva bulb in the US at your local PepBoys. But the Narva number is 17094.
The bulb is as pictured and is a 12 volt, 3 watt, SV 7 socket base. The overall bulb length is 28 to 29mm depending on who makes them. And about 6 to 8 mm wide.
You will probably have better luck finding the Sylvania bulb, part #6428. Actually, see if you can get the Sylvania #DE3021 - that is more or less the same but has a rated life of 1000 hours. Which should last until your car goes to the crusher.
With the glove box light the switch will stick for just that last little bit, just enough that it won't work. Try pulling the black part out,after I bought a new switch I found this out.
i found the light part no
here it is..
E-632-113-00
you can order it here for $12 too f%@#ing expensive if you ask me though...
http://www.pelicanparts.com/catalog/...interi_pg3.htm
here it is..
E-632-113-00
